[Geoserver-devel] GSIP-157 - Track change state in CatalogPostModifyEvent
This was initially proposed just prior to the 2.11-beta release, but did not make it in in time.
Re-opening for discussion and voting now that the code freeze has ended.
Refer to https://github.com/geoserver/geoserver/wiki/GSIP-157
This proposal is to update the CatalogPostModifyEvent (and associated firePostModifed methods) to track changed values, similar to the current implementation of CatalogModifyEvent.
This requires some API changes in a few catalog methods and interfaces.
Ultimately, it is a useful, but relatively minor change requiring some not-backwards-compatible API changes to the core catalog implementation.
Full set of proposed changes can be seen in the pull request.
Torben
Hi Torben,
it would help, imho, if the proposal separated the API changes that are actual backwards incompatible ones.
E.g., adding method to the event class is not an API break at all.
Makes easier to argue that the changes are isolated in places that are not really meant to be implemented
outside of GeoServer. Just my 2 cents.
On Mon, Mar 20, 2017 at 5:09 PM, Torben Barsballe <tbarsballe@anonymised.com3839…> wrote:
Torben
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
I took a look, and none of the changes are strictly backwards-compatible
The changes to CatalogPostModifyEvent are changes to a public interface.
The changes to AbstractCatalogFacade are protected, but will affect anything extending AbstractCatalogFacade.
Everything else is mostly just implementing the interface changes, and depends upon the changes above. I have updated the GSIP to make this delineation more clear.
Torben
On Mon, Mar 20, 2017 at 10:15 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Torben,
On Mon, Mar 20, 2017 at 5:09 PM, Torben Barsballe <tbarsballe@anonymised.com9…> wrote:
Torben
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
+1. Seems necessary, and the changes are not too intrusive.
Kind regards,
Ben.
<https://github.com/geoserver/geoserver/pull/2101&gt;\.
Torben
Check out the vibrant tech community on one of the world's most
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Thanks for the clarification
+1 then :slight_smile:
On Mon, Mar 20, 2017 at 6:31 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Hi Torben,
On Mon, Mar 20, 2017 at 5:09 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
+1 from me
Ian
On Mon, Mar 20, 2017 at 6:31 PM, Torben Barsballe <tbarsballe@anonymised.com…> wrote:
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Torben,
Torben
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Now that this has gotten at least 50% +1’s, are we good to merge? PR is here: https://github.com/geoserver/geoserver/pull/2101
Torben
On Tue, Apr 4, 2017 at 10:30 AM, Kevin Smith <smithkm@anonymised.com9…> wrote:
+1
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
It’s bee a while too, no objections, so yeah (imho, but I don’t remember the rules by heart)
On Mon, Apr 10, 2017 at 6:40 PM, Torben Barsballe <tbarsballe@anonymised.com3839…> wrote:
Torben
+1
Kevin Michael Smith
[<smithkm@anonymised.com9...>](mailto:smithkm@anonymised.com)
Ing. Andrea Aime
@geowolf
Technical Lead
