[Geoserver-devel] GSIP 158 - NetCDF Output Support for Variable Attributes and Extra Variables
Preliminary GSIP for discussion, no Jira issues yet:
https://github.com/geoserver/geoserver/wiki/GSIP-158
Motivation
NetCDF/GRIB sources contain rich metadata in the form of variable attributes and extra variables that give meaning to data. When a coverage is read from a NetCDF/GRIB source, this information is lost, even if the output from GeoServer is NetCDF that is capable of representing this information.
Proposal
Functionality
For NetCDF output add:
1. An option to allow all attributes to be copied from the source NetCDF/GRIB variable to the target variable
2. Support for manual configuration of variable attributes, much like the current support for setting global attributes
3. Support for configuration of extra variables which are copied from the NetCDF/GRIB source to the output; initially only scalar variables will be supported
4. An option for each extra variable to be expanded over dimensions, that is, values copied from one scalar per ImageMosaic granule are assembled into a multidimensional variable over, for example, time and elevation
The GSIP has screenshots of the current settings tab and a rough draft of the proposed settings tab.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
I have added some GitHub branch comparisons in the implementation section. The implementation is incomplete; discussion comes first. It is still too early for pull requests.
Director
New Zealand
I have submitted pull requests for review.
See the GSIP 158 page for screenshot and user manual:
A small change is required to GeoTools:
[GEOT-5709] Support coverage property SourceUrl
https://github.com/geotools/geotools/pull/1564
https://osgeo-org.atlassian.net/browse/GEOT-5709
Most of the implementation is in GeoServer:
[GEOS-8099] GSIP 158 - NetCDF output support for variable attributes and extra variables
https://github.com/geoserver/geoserver/pull/2281
https://osgeo-org.atlassian.net/browse/GEOS-8099
Kind regards,
Ben.
Director
New Zealand
Hi Ben,
I’ve lost track of this one, seems like a step was skipped?
No big deal, but checking the history I see GSIP-158 switching from
a “preliminary discussion” thread (unfortunately empty) to a pull
request without a vote in the middle.
Have I missed it?
No big deal, we can vote and review at the same time.
On Tue, Apr 25, 2017 at 5:09 AM, Ben Caradoc-Davies <ben@anonymised.com> wrote:
extra variables
Kind regards,
Ben.
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andrea,
this proposal is (almost) entirely confined to one module (gs-netcdf-out), changes no API, is (almost) fully backwards compatible in behaviour, and is fully backwards compatible in serialised settings. The GSIP might not even be required, but I thought it a useful way to ask for comments. I do not expect it to be contentious; I welcome all feedback.
There was some prior discussion on GeoTools PR #1417 <https://github.com/geotools/geotools/pull/1417&gt; which was most helpful in dissuading me from that approach, and I also got an off-list analysis of the cost of opening NetCDF/GRIB files (I have asked for permission to copy it as a Jira comment).
I agree that there was no response to my original proposal, perhaps because of the REST migration sprint, and perhaps because a module maintainer was on leave. The only feedback I got on this one was your comment on GEOT-5709 (thanks!). I hope that the screenshot, user manual section, and fully implemented pull requests will attract more attention.
Kind regards,
Ben.
On 25/04/17 18:44, Andrea Aime wrote:
Hi Ben,
I've lost track of this one, seems like a step was skipped?
a "preliminary discussion" thread (unfortunately empty) to a pull
Have I missed it?
extra variables
Kind regards,
Ben.
Director
New Zealand
Check out the vibrant tech community on one of the world's most
Director
New Zealand
On Tue, Apr 25, 2017 at 1:59 PM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
Andrea,
Hi Ben,
I did not look at it and don't know if it's proposal worthy. But I believe
that, message wise, it's problematic to stand up a
proposal and then move on without a discussion on it, others might follow
in your footsteps for stuff that is truly
proposal worthy (because it happened before, you know, it sets a precedent,
and people are not always inclined
to check the details or context and just get the narrative suiting them and
go with it).
Ing. Andrea Aime
@geowolf
Technical Lead
You could move the page to https://github.com/geoserver/geoserver/wiki/Maintenance if a vote is not needed.
I would also be willing to combine the proposal page and the maintenance page so we get a consistent breakdown of changes by version number.
On 25 April 2017 at 04:59, Ben Caradoc-Davies <ben@anonymised.com> wrote:
Andrea,
feedback.
<https://github.com/geotools/geotools/pull/1417> which was most helpful
Kind regards,
Ben.
Hi Ben,
Have I missed it?
extra variables
Kind regards,
Ben.
Ben Caradoc-Davies <ben@anonymised.com91…>
Director
New Zealand
Geoserver-devel@anonymised.comsourceforge.net
Director
New Zealand
Jody Garnett
go with it).
Andrea, I agree. It is also risky to implement a proposal when someone might have a good objection that requires a completely different approach and much rework. The purpose of a GSIP is to obtain agreement before expending effort on an implementation. I did not know how to proceed in the absence of any response to the discussion thread or to other list emails to requesters of these features. Would it have been better to call for a vote to force discussion? I was hoping that a concrete implementation would attract more attention. In any case, I will wait for comments and reviews and change the implementation if required.
Kind regards,
Director
New Zealand
On Tue, Apr 25, 2017 at 11:01 PM, Ben Caradoc-Davies <ben@anonymised.com>
Hum... I am not sure, but something like this might have worked:
   - "Threaten" to go to vote on the original thread as a follow up (it
   seems nobody has a problem with this, so I'll start the vote in 1-2 days)
   - Vote for good if no more feedback comes on
Yep, implementing along before vote is not prohibited, it just increases
the risk of reworking and it's all on you :-p
Ing. Andrea Aime
@geowolf
Technical Lead
That sounds good to me.
Indeed it is, but feedback is valuable and I will not begrudge some rework if it makes the final product better. :slight_smile:
Kind regards,
Director
New Zealand
