GeoServer currently uses a rather ugly and brittle mechanism to apply data security (Certain users should only be able to view certain layers or certain parts of layers) to the service endpoints of its internal GWC instance.
This proposal is to add an API to GeoWebCache to do security checks which GeoServer can extend to apply its own security rules deeper inside GWC, after the service endpoints have parsed the request into a universal Conveyor object.
Extension point that the GeoWebCacheDispatcher can call to generate appropriate security context object to be stored on the resulting Conveyor
interface SecurityContextProvider<Context> {
public Context getSecurityContext(HttpRequest request)
Add accessors for a securityContext property to Conveyor. GeoWebCacheDispatcher calls Service.getConveyor to get a Conveyor, then handles it. The context would be attached in between those steps.
Add a SecurityException class. Allow it to wrap another exception so it can wrap the GeoServer one, which might then be extracted if need be. Amend method signatures to allow throwing this exception.
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
Kevin Michael Smith
Hi Kevin,
the current security mechanism in GeoServer work off an Authentication, this one
seems to be based on Spring own SecurityContext, but the API you shown says that’s an Object…
Can you clarify how that fits toghether and the rationale behind the different approach?
Kevin Michael Smith
Hi Kevin,
says that's an Object....
different approach?
This is the API for upstream GeoWebCache and I didn't want to unduly
restrict future development there. I'm happy to consider making Spring
Security part of the GWC API, but being flexible seemed like a better
starting point for discussion.
Kevin do you want to take this opportunity to make use of spring security?
This proposal has been held open for a while now and I want to make sure you are not stuck.
Hi Kevin,
different approach?
This is the API for upstream GeoWebCache and I didn’t want to unduly
restrict future development there. I’m happy to consider making Spring
I’ve updated the proposal with Andrea’s suggestion of not passing the context as a parameter and using out of band context like a thread local from Spring Security)
At this point there’s not a lot of API change left. Just adding the new interface and expanding which exceptions are thrown.
Using AcessControlException as Jody suggested bothers me a bit as the Javadocs tie it to specific other components. I do like the idea of existing exception classes, although a subclass of GeoWebCacheException would probably be less disruptive.
Hi Kevin,
different approach?
Kevin Michael Smith
Hi Kevin,
different approach?
I've updated the proposal with Andrea's suggestion of not passing the
At this point there's not a lot of API change left. Just adding the new
Jody Garnett
On 19 June 2017 at 14:29, Kevin Smith <smithkm@anonymised.com
<mailto:smithkm@anonymised.com>> wrote:
On 6/17/17 10:53 AM, Andrea Aime wrote:
> Hi Kevin,
shown
> different approach?
Spring
Kevin Michael Smith
<smithkm@anonymised.com <mailto:smithkm@anonymised.com>>
Check out the vibrant tech community on one of the world's most
