Time dimension at least in image mosaics is not quite similar than for example spatial dimensions because it is not really continuous and it usually does not make sense for example to interpolate values from orthophotos which are acquired in different years. See an excerpt from DescribeCoverage
<wcsgs:TimeDomain default=“2017-01-01T00:00:00.000Z”>
<gml:TimeInstant gml:id=“ortotesti__ortokuva_td_0”>
gml:timePosition1985-01-01T00:00:00.000Z</gml:timePosition>
</gml:TimeInstant>
<gml:TimeInstant gml:id=“ortotesti__ortokuva_td_1”>
gml:timePosition1986-01-01T00:00:00.000Z</gml:timePosition>
</gml:TimeInstant><gml:TimeInstant gml:id=“ortotesti__ortokuva_td_2”>
gml:timePosition1988-01-01T00:00:00.000Z</gml:timePosition>
</gml:TimeInstant>
We have been thinking what should happen with an orthophoto coverage if WCS user is asking for a time range that does not include any TimeInstant, or if range covers many TimeInstants. The latest TimeInstant within the range, or the closest one in the past if nothing is found otherwise might suit for us. For some other kind of coverages like meteorological data that is not good approach but users probably want to get strictly what they ask as multilayer netCDF file or animated GIF or whatever.
-Jukka Rahkonen-
Lähettäjä: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] Puolesta Andrea Aime
Lähetetty: 22. helmikuuta 2018 10:58
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@maanmittauslaitos.fi>
Kopio: Geoserver-devel <geoserver-devel@anonymised.comsourceforge.net>
Aihe: Re: [Geoserver-devel] GSIP 166 - Support for controlled nearest match on time dimension
Hi Jukka,
the proposal is targeted solely at WMS, but the code is being setup so that the same facilities
can be reused for WCS as well, in case someone wants to.
I’m not sure WCS has any way to advertise such support, and time is just another dimension there,
e.g., is it treated the same as spatial ones.
On Thu, Feb 22, 2018 at 9:35 AM, Rahkonen Jukka (MML) <jukka.rahkonen@maanmittauslaitos.fi> wrote:
+1
Will it work also with WCS 2.x for time positions and ranges?
-Jukka Rahkonen-
Lähettäjä: Andrea Aime [mailto:andrea.aime@anonymised.comsolutions.it]
Lähetetty: 20. helmikuuta 2018 17:32
Vastaanottaja: Geoserver-devel <geoserver-devel@anonymised.comsourceforge.net>
the mailing list issues caused some delays, a few people already cast their vote directly
on the GSIP and notified on gitter.
Hopefully the list is back in working state, keep the feedback/votes coming
On Mon, Feb 19, 2018 at 5:36 PM, Andrea Aime <andrea.aime@anonymised.com8…> wrote:
as briefly suggested during a recent GSIP meeting, here is the proposal for adding WMS nearest match support on time dimension:
https://github.com/geoserver/geoserver/wiki/GSIP-166
The proposal is limited to time due to resource limitations, but care will be taken not prevent/complicate future support
for elevation and custom dimensions.
The proposal is currently scheduled for 2.14.x, although a request for backport might happen at a later date.
Please discuss, or if you’re happy with the proposal as is, cast a vote
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Alessio Fabiani
mob: +39 331 6233686
