By the comparison http://www.java-logging.com/comparison/ I would have liked to see also a proposal for logback that by the feature table seems to be on the same line with log4j, but we do not have such proposal.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Just to confirm the proposal has been accepted and I have availability to work on this next week. The release candidate may be delayed, but it will be great to have this done!
Thanks to everyone for the votes, financial support, and many encouraging emails sent.
