+1
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
Con riferimento alla normativa sul trattamento dei dati personali
(Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
“GDPR”), si precisa che ogni circostanza inerente alla presente email
(il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
conoscenza è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential
or otherwise protected from disclosure. We remind that - as provided
by European Regulation 2016/679 “GDPR” - copying, dissemination or use
of this e-mail or the information herein by anyone other than the
intended recipient is prohibited. If you have received this email by
mistake, please notify us immediately by telephone or e-mail.
On Wed, Jul 10, 2019 at 10:53 AM Nuno Oliveira
<nuno.oliveira@anonymised.com> wrote:
Thank you all for the feedback, answering the open points:
regarding the naming:
what do you think about renaming it to system-status?
regarding the promotion to core, I would suggest the following steps:
promote to extension in 2.15.x
promote to core in master (2.16.x)
Do we have a enough information to start a vote? if yes I will kindly ask you to vote on this GISP
On Wed, 2019-07-10 at 10:00 +0200, Andrea Aime wrote:
On Wed, Jul 10, 2019 at 1:23 AM Nuno Oliveira GeoSolutions <nuno.oliveira@anonymised.com> wrote:
- could consider taking this functionality into core rather than as an extension?
Works for me, this module doesn't do anything unless the 'Monitoring' tab is accessed, in the future if the functionality is extend to include a small historic \ graphs then we will to give the option to the admin to deactivate the metrics collectors.
Hum... core directly? I did not see that coming.
But If that's the case, a simple way to solve the naming problem, is not to name it, and spread its classes
in gs-main, gs-restconfig and gs-web-core instead
Just thinking out loud
Of course, there is a downside of going this direction... it makes proposing a backport harder, I think it's the
first time a module goes straight from community to core (actually, the first time anything in extension or community
goes in core, in a very long long time).
That said, the module is really a handful of classes and I know first hand it has been added to a lot of
installations so far so... no objection.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Nuno Oliveira
experts!
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Geoserver-devel mailing list
