[Geoserver-devel] GSIP 177 - Support for vector custom dimensions
Hi all, Project Steering Committee,
I would like to add support for vector custom dimension on WMS service,
I wrote a GSIP document in the link:
https://github.com/geoserver/geoserver/wiki/GSIP-177
Of course, I’ll be glad to get your feedback.
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
This proposal is targeted towards 2.16? We are days away from the RC deadline …
As for the content of the proposalL
  • Technically this functionality is already available for GetMap via CQL_FILTER is it not?
  • Do you have an example of WMS 1.1 and WMS 1.3 snippet advertising custom dimensions, an identical approach as for time
  • there is a risk of conflict between dimension parameters (population=100 in the demo) and other keys, perhaps something similar to vendor options should be considered? Imagine if I had a dimension named format, angle or env?
Jody Garnett
Same goes for the existing TIME and ELEVATION support for vectors, they could be done via CQL_FILTER. But CQL_FILTER cannot be discovered by a generic OGC WMS client, custom dimensions are instead part of the WMS standard.
It’s really the same as the exiting support for raster custom dimensions (WMS does not tell you if a particular layer is vector or raster).
Here is an example taken from a GeoServer serving a raster data set with dimensions time, elevation and REFERENCE_TIME:
2016-02-23T03:00:00.000Z,2016-02-23T06:00:00.000Z,2016-02-23T09:00:00.000Z,2016-02-23T12:00:00.000Z,2016-02-23T15:00:00.000Z,2016-02-23T18:00:00.000Z,2016-02-23T21:00:00.000Z,2016-02-24T00:00:00.000Z,2016-02-24T03:00:00.000Z,2016-02-24T06:00:00.000Z,2016-02-24T09:00:00.000Z,2016-02-24T12:00:00.000Z,2016-02-24T15:00:00.000Z,2016-02-24T18:00:00.000Z,2016-02-24T21:00:00.000Z,2016-02-25T00:00:00.000Z,2016-02-25T03:00:00.000Z,2016-02-25T06:00:00.000Z,2016-02-25T09:00:00.000Z,2016-02-25T12:00:00.000Z,2016-02-25T15:00:00.000Z,2016-02-25T18:00:00.000Z,2016-02-25T21:00:00.000Z,2016-02-26T00:00:00.000Z,2016-02-26T03:00:00.000Z,2016-02-26T06:00:00.000Z,2016-02-26T09:00:00.000Z,2016-02-26T12:00:00.000Z,2016-02-26T15:00:00.000Z,2016-02-26T18:00:00.000Z,2016-02-26T21:00:00.000Z,2016-02-27T00:00:00.000Z,2016-02-27T03:00:00.000Z,2016-02-27T06:00:00.000Z,2016-02-27T09:00:00.000Z,2016-02-27T12:00:00.000Z,2016-02-27T15:00:00.000Z,2016-02-27T18:00:00.000Z,2016-02-27T21:00:00.000Z,2016-02-28T00:00:00.000Z 0.0,200.0,400.0,600.0,800.0,1000.0,1200.0,1400.0,1600.0,1800.0,2000.0,3000.0,4000.0,5000.0,6000.0,7000.0,8000.0,9000.0 2016-02-23T00:00:00.000Z,2016-02-24T00:00:00.000Z,2016-02-25T00:00:00.000Z
The WMS specification handle this by asking the client to add a “DIM_” prefix in the request, so if the dimension is called “REFERENCE_TIME” the client will add a parameter &DIM_REFERENCE_TIME=value in the KVP request.
Being part of the core specification, servers adding vendor parameter are forbidden to add ones starting with DIM_, thus avoiding conflicts.
Again, this is already supported for raster data, see for example this test suite:
https://github.com/geoserver/geoserver/blob/31a1aff264cac7e3db20edc776dd5a84bd58ce02/src/wms/src/test/java/org/geoserver/wms/wms_1_1_1/CustomDimensionsTest.java
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Wed, 14 Aug 2019 at 11:02, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Wed, Aug 14, 2019 at 7:49 PM Jody Garnett <jody.garnett@anonymised.com…> wrote:
Andrea did you have any feedback on this? I would expect hold off until after freeze, wait a month and back port?
That makes perfect sense, a real gap in the standards not having a good overview of available values for attributes.
Thanks.
Okay there is a small mistake in the proposal where &poluation=10000 was used.
I am +1 on the proposal, +0 on including it in the 2.16-RC timeframe…
+1 for me.
Ian
Ian Turton
Dear all,
I absolutely agree with this proposal. Since we already support custom dimensions for Raster, I don’t see why support should not be implemented for VECTORs also.
Moreover, having them advertised on the WMS GetCapa would be also very nice improvement.
Here my +1.
Not fully sure if this should be included into the RC as Jody pointed out. +0 for me also on this topic.
Alessio.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
+1
It is a good occasion to align raster and vector support.
Simone.
Simone Giannecchini.
GeoSolutions Director
  • sent from my mobile, apologies for brevity and typos-
Dear all,
a follow up on this one:
The proposal has been updated, as suggested, to include this in 2.17-RC and in a month from now to backport to 2.16.1.
The PR for 2.17.x (master) is available here, and ready to merge:
https://github.com/geoserver/geoserver/pull/3732
Thank you all for the feedback!
On Wed, Aug 14, 2019 at 7:49 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks.
Geoserver-devel mailing list
[Geoserver-devel@anonymised.comsts.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
experts!
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
+1
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
