I have updated the “admin” list on sourceforge, I left gtbuilder in the “admin” list as I expect it is needed by the build server.
There is also a “Developer” list that contains inactive individuals such as Mark Leslie, James Macgill and Rob Hranac … it looks like the group only as “read” access so I did not clean it up.
HI Jody,
I did lost track of it and the final cleanup was not done… went back to the thread where
I asked for a “show hand up” and removed the people that did not answer.
As far as I’m concerned the GSIP work is done.
I did not touch the sourceforge devel list, as we don’t keep the sources there anymore, but
if you feel it’s important, please go ahead and clean up there too
Jody Garnett
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.ithttp://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
