With the GeoTools pr underway, I would like to motion that GSIP-184 go ahead:
I will start working on the pull request (in keeping with the tasks outlined in GSIP-184).
Jody Garnett
Jody Garnett
Hi Jody,
read it, I see again a “I don’t know the test coverage level” without any further elaboration.
I tried to get coverage myself using the jacoco profile in the main pom that Gabriel setup
(I don’t know if it’s working properly, but referred it to you more than once by now).
Unfortunately tests are not passing, so could not get a result:
[INFO] Running org.geoserver.community.mbstyle.web.MBStyleEditPageTest
[ERROR] Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 7.332 s <<< FAILURE! - in org.geoserver.community.mbstyle.web.MBStyleEditPageTest
[ERROR] testMbstyleChange(org.geoserver.community.mbstyle.web.MBStyleEditPageTest) Time elapsed: 6.873 s <<< ERROR!
java.lang.ClassCastException: org.geotools.styling.TextSymbolizerImpl cannot be cast to org.geotools.styling.PointSymbolizer
at org.geoserver.community.mbstyle.web.MBStyleEditPageTest.testMbstyleChange(MBStyleEditPageTest.java:94)
[INFO] Running org.geoserver.community.mbstyle.web.MBStyleHandlerTest
[ERROR] Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.779 s <<< FAILURE! - in org.geoserver.community.mbstyle.web.MBStyleHandlerTest
[ERROR] testRoundTripMBStyleGroup(org.geoserver.community.mbstyle.web.MBStyleHandlerTest) Time elapsed: 0.753 s <<< FAILURE!
java.lang.AssertionError: expected:<4> but was:<3>
at org.geoserver.community.mbstyle.web.MBStyleHandlerTest.testRoundTripMBStyleGroup(MBStyleHandlerTest.java:57)
[INFO] Running org.geoserver.rest.catalog.MBStyleControllerTest
[INFO] Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.947 s - in org.geoserver.rest.catalog.MBStyleControllerTest
Can you please fix the tests and get a report?
Or even just a statement like “will fix the tests, make sure the coverage is at least 40%, and update the GSIP later”.
Regards
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks Andrea, I was unable to get acoco running on geotools, and have not yet tried on geoserver.
Updating the text of the proposal for now.
Jody Garnett
GeoTools does not have the same profile AFAIK. If it works, we can migrate it back to GT.
Thanks, +1 then
+1
+1
Torben
On Thu, Feb 13, 2020 at 3:40 AM Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
+1
On Mon, 2020-02-10 at 10:17 +0100, Andrea Aime wrote:On Mon, Feb 10, 2020 at 10:14 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Thanks, +1 then
Andrea== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
_______________________________________________ Geoserver-devel mailing list [Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net) [https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
-- Regards, Nuno Oliveira == GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information. == Nuno Miguel Carvalho Oliveira @nmcoliveira Software Engineer GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) Italy phone: +39 0584 962313 fax: +39 0584 1660272 [http://www.geo-solutions.it](http://www.geo-solutions.it) [http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it) ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
