[Geoserver-devel] GSIP 197 - Promote WPS-JDBC to extension status
one more (and hopefully the last) module gradation GSIP from me:
https://github.com/geoserver/geoserver/wiki/GSIP-197
The wps-jdbc module is a WPS asynchronous status store we have been using more and more,
as wps-hazelcast (the existing supported equivalent) is not always working in environments where
multicast is disabled and the IP of the WPS cluster nodes are not predictable and config time
(but the one of a database, is).
I’ll start with my +1
== GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
+1
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
+1
And I’m happy to be listed as a co-maintainer on this module.
Ian
Ian Turton
The proposal has been available for well over the required 10 days,
got no negative votes, as such, it is passed. PR incoming
Regards, Andrea Aime
