[Geoserver-devel] GSIP 200 Promote MapML to extension
+1
-Jukka Rahkonen-
Lähettäjä: peter.rushforth@anonymised.com peter.rushforth@anonymised.com
Lähetetty: perjantai 19. helmikuuta 2021 15.43
Vastaanottaja: geoserver-devel@lists.sourceforge.net
Aihe: [Geoserver-devel] GSIP 200 Promote MapML to extension
It was suggested that in order to get this module tested on a nightly basis, it might be worthwhile doing the work to promote it to an extension.
Now I’m willing to do the work, with a little bit of guidance, so I wrote up a GSIP about it over here: https://github.com/geoserver/geoserver/wiki/GSIP-200
We recently committed some tests and bug fixes, Javadoc formatting and viewer/preview improvements, which although they aren’t complete (73% coverage, 49% branch coverage), I intend to improve them as the functionality of the module improves.
Please consider this request and vote on it, if you think it ready for that, and send any feedback to me.
Thank you.
Pete Rushforth
+1
Nuno Oliveira
Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
Con riferimento alla normativa sul trattamento dei dati
personali (Reg. UE 2016/679 - Regolamento generale sulla
protezione dei dati “GDPR”), si precisa che ogni
circostanza inerente alla presente email (il suo contenuto,
gli eventuali allegati, etc.) è un dato la cui conoscenza
è riservata al/i solo/i destinatario/i indicati dallo
scrivente. Se il messaggio Le è giunto per errore, è
tenuta/o a cancellarlo, ogni altra operazione è illecita.
Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to
which it is addressed and may contain information that
is privileged, confidential or otherwise protected from
disclosure. We remind that - as provided by European
Regulation 2016/679 “GDPR” - copying, dissemination or
use of this e-mail or the information herein by anyone
other than the intended recipient is prohibited. If you
have received this email by mistake, please notify
us immediately by telephone or e-mail.
+0
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
