Dear all,
I would like to propose the addition of style support for LayerGroup.
Please consider reviewing the proposal available here.
The improvement aims to add a notion of style to LayerGroup as the possibility to define multiple sets of layers and styles as different named configurations.
The various named configurations will be advertised in the WMS getCapabilities response as styles so that can be requested through the usage of the styles parameter in WMS operations.
Marco Volpini
Visit http://bit.ly/gs-services-us for more information.
Marco Volpini
Software Engineer
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
