[Geoserver-devel] GSIP-206 Promote GeoPackage to extension
Please have a look at
https://github.com/geoserver/geoserver/wiki/GSIP-206 which outlines moving different sections of the geopackage community module into the appropriate core module: gs-wfs, gs-wms, and gs-wps.
The proposal is solid, please make note of the backwards compatibility section which proposes calling out wps geopackage supports for not yet finalized extensions. While there is nothing wrong with having geoserver specific extensions they should be documented as such (and marked as in progress if they are chasing a moving target). If folks feel strongly about documentation not being enough warning I can look at leaving these geopackage extensions as an optional install.
Jody
Jody Garnett
Hi Jody,
checking the proposal, I believe the title is misleading, it seems to suggest a classic module move from community to extension, as is… which does not match the actual proposal.
The actual proposal is:
  • Fold the WFS output format gs-wfs, the WMS output format in gs-wms, hence, move these two bits in core
  • Fold the WPS process in gs-wps-core
    About the move to cover of the WMS/WFS output formats, from a technical point of view I’m not concerned:
  • The WFS output format will eventually break for large outputs due to HTTP time outs (needs to be written on disk first, streamed back once complete), but the same already happens for zipped shapefiles, so nothing really new
  • The WMS output format now honors the rendering time outs, so it should be fine
    I should however point out that the core of GeoServer is “maintained by the PSC” so the rest of the PSC should be comfortable having that code in core, and realize the associated obligation.
About the move of the WPS process to wps-core, I’m also personally not deeply concerned, if the documentation
is very clear about the experimental extensions baked into the process (so doc updates are needed).
I’m however noting the code moving also moves its maintainership from “nobody” to me (the WPS module maintainer), which I’m not too fond of [1].
Since you’re making the proposal, I’d like you to step up as co-maintainer of the code you’re trying to push up. For the core bits, as a PSC member, you’re taking that
responsibility automatically anyways. Please step up to co-maintain the processes once moved in gs-wps-core.
[1] Due to both project and business obligations I’m responsible for way too many modules already,
something which is too big of a onus on my shoulders, and a big project liability in case I get sick
or decide to leave. It’s something we’ll have to address, possibly sooner rather than later.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Thanks Andrea, I will rename the proposal.
I have capacity to support the wps module on this one (as indeed a customer is funding this activity).
Jody
Jody Garnett
Proposal is renamed.
With respect to gs-wps module I would like to see the matching gt-wps unsupported module which forms its foundation cleaned up (finally). Something we can discuss in the new year.
Jody Garnett
Looking at the proposal now, +1 from me.
Torben
On Thu, Dec 30, 2021 at 7:42 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
On Thu, Dec 30, 2021 at 5:11 AM Andrea Aime <andrea.aime@anonymised.com…6887…> wrote:
Hi Jody,
On Thu, Dec 30, 2021 at 5:28 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
Jody Garnett
Geoserver-devel mailing list
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
And +1 here too
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Good Morning Jody,
I am not too inclined on having the gpkg output jump from community to core for WMS and WFS.
The process we have in place is there to exactly prevent something like this from happening because “someone needs it urgently”.
I mean, have you been using them in production enough to be confident with them? Do you already have a sizable number of clients using the extensions so we can trust them? I guess not given what you said above…
For the moment my vote is a -1 on this, but I am happy to hear your thoughts on my points above.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director GeoSolutions Italy
President GeoSolutions USA
http://www.geosolutionsgroup.com
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
On Fri, Dec 31, 2021 at 1:50 AM Jody Garnett <jody.garnett@anonymised.com.> wrote:
Jody Garnett
On Thu, 30 Dec 2021 at 07:40, Jody Garnett <jody.garnett@anonymised.com…> wrote:
Jody
On Thu, Dec 30, 2021 at 5:11 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Jody,
Jody
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Simone, this is the definition of slow moving and not urgent. I first asked if this was a good idea around 2 years ago as a customer is interested. Procurement moves slowly, funding has now come through to do this activity. The customer has been using geopackage WFS output for at least three years. Indeed this funding is as a result of a review of the community modules the customer is using in production, and asking if they would be interested in helping it be cleaned up and made into an official extension.
While I do not have a sizable number of clients, once this functionality has been cleaned up I will be adding it to the geocat enterprise products for all our customers (presently it is an option by request).
Let’s review the checklist:
1. The module has at least a “handful” of users.
I have three users of this functionality, only one I would consider as using it in production.
2. The module has a designated and active maintainer
I offered to join Andrea on this (on the assumption the functionality can be cleaned up and be included in geocat enterprise products).
3. The module is considered “stable” by the majority of the PSC
I checked in with this on november/decemeber expecting wfs and wps to be stable and wms output format to be removed. Andrea asked me to revise the proposal to include gs-wms.
So far my personal testing has been mixed, EPSG:4326 output is coming out in Y/X order which does not match up with the specification:
The axis order in WKB stored in a GeoPackage follows the de facto standard for axis order in WKB and is therefore always (x,y{,z}{,m}) where x is easting or longitude, y is northing or latitude, z is optional elevation, and m is optional measure. This ordering explicitly overrides the axis order as specified in the SRS metadata, applying Case 4 from OGC 08-038r7, Revision to Axis Order Policy and Recommendations[K11]. This was done to maintain consistency with previous implementations of WKB that predated the OGC policy.
The above indicates additional QA is needed. You can also see the proposal where I noted frustration with a couple design decisions.
4. The module maintains 40% test coverage
The coverage looks good, but I have not measured it.
5. The module has no IP violations.
So far everything seems to be original work, with links to OGC where appropriate. If something comes up during the activity I will let you know.
6. The module has a page in the user manual
Not directly useful as the documentation will be distributed across several pages:
I also note geosolutions has training materials https://docs.geoserver.geo-solutions.it/edu/en/wps/geopackage_output.html
7. The maintainer has signed the GeoServer Contributor Agreement
OSGeo has a signed CLA from both myself and GeoCat BV.
Jody Garnett
Jody,
Even though I am not entitled to vote, I’d like to point out that experiences from Testbed 17 clearly show that it is not wise to use GPKG as output format to synchronous WMS and WFS requests issued by users.
Each request binds resources until the GeoPackage is complete. Cancellation is not possible. If the GeoPKG production takes too long, the user may “click” again and again and again and thereby cause binding of resources for completing the same request that perhaps is still in progress (but defunct). The fact that the client is no longer able to consume the response (either connection timeout or user cancelled the request) is found out only after the GeoPackage is fully produced and to be send to the client (IO Exception as socket is closed). Until then, all necessary resources of the thread (CPU, Memory, diskspace) are bound to produce a GeoPackage for nothing…
In addition we found the GeoPackage axis order issue (as you point out in #3) and reported that as bug: https://osgeo-org.atlassian.net/browse/GEOT-7011
Best
Andreas
Date: Wednesday, 5. January 2022 at 03:16
To: Simone Giannecchini simone.giannecchini@anonymised.com
Cc: Geoserver Devel geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] GSIP-206 Promote GeoPackage to extension
Jody Garnett
On Tue, 4 Jan 2022 at 14:23, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Good Morning Jody,
Simone Giannecchini
@simogeo
On Fri, Dec 31, 2021 at 1:50 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Thu, 30 Dec 2021 at 07:40, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody
Hi Jody,
· Fold the WFS output format gs-wfs, the WMS output format in gs-wms, hence, move these two bits in core
· Fold the WPS process in gs-wps-core
· The WFS output format will eventually break for large outputs due to HTTP time outs (needs to be written on disk first, streamed back once complete), but the same already happens for zipped shapefiles, so nothing really new
· The WMS output format now honors the rendering time outs, so it should be fine
Jody
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Geoserver-devel@anonymised.comforge.net
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@anonymised.comourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Hi Jody,
the checklist should be part of the proposal :wink:
Maybe Simone’s worries can be addressed by just upgrading the module as an extension, instead of splitting it and folding it into core modules?
The gs-wms and gs-wfs have somehow limited usage anyways, can only be used to make small exports that would not trigger an HTTP timeout
(I have seen 1 to 5 minutes timeouts in pratical deploys).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Agree on the issue, but I would not be so bleak about it. GeoServer WFS has had SHAPE-ZIP output format in core for almost as long as WFS existed,
and it shares the same limit, it can only be used for smaller downloads.
If that turns into a problem, then I’d argue WFS is mis-configured: there is a maximum feature count setting in WFS, which can be used
to limit the size of the generated GeoPackage to a reasonable size (defaults to one million, maybe a bit too much :smiley: ).
Of course you would not be able to download a large dataset in a single request, but that’s why WFS provides paging.
Download of large packages as single files should definitely be done via WPS async requests (but even there, you cannot
force a client to make a async request, the client is in control, not the server).
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Hi Jody,
I second what Andrea said, I’d be much more confident if we followed the usual path and we made the gpkg output for WMS and WFS as an official extension.
In time we can move it to core but at the moment I still don’t feel like these modules are ready.
Let me know what you think.
Simone Giannecchini
@simogeo
I understand the limitations, downloading WFS output as a shape file is always popular and subject to the same difficulties you describe.
I think this is more a problem with the WFS workflow than a limitation of the file format.
Jody
Jody Garnett
Simone
So the counter proposal is to take WFS and WMS into their own (very small) extensions, and leave WPS functionality behind as a community module. I am aware that the wps download extension offers very simple geopackage output for a single layer.
I will need to check if that is okay.
Jody
Jody Garnett
Hi Jody,
no my proposal is:
  • GPKG output for WMS and WFS becomes an official extension
  • GPKG output for WPS gets folded in WPS
    or any variation over this.
I am not confident in having GPKG output for WMS and FS jump directly into core but we shall try to find a middle ground to not block your work.
Feel free to propose something else along these lines.
Simone Giannecchini
@simogeo
I am not sure I understand your statement “or any variation over this” - what do you mean?
I am presently trying to make sure I understand your feedback here, and testing fixes for geopackage axis order (GEOS-8793,GEOT-7011).
Jody Garnett
“or any variation over this” means that you can propose something different from what I propose as long as it does not involve GPKG formats for WMS and WFS to end up in core right away.
Simone Giannecchini
@simogeo
Thanks for the clarification Simone, I will update the proposal accordingly.
Jody Garnett
Simone, please review the revised proposal: https://github.com/geoserver/geoserver/wiki/GSIP-206
For anyone else who voted previously you may wish to double check your response.
Jody Garnett
Hi Jody,
I am +0 now.
Two things:
  • I don’t want to be involved too much with the coding but this part surprised me:
    “To migrate to core: GeoPkgDataStoreFactoryInitializer.java this should of been done previously as part of adding datastore support”
Do we really need to have plugin specific code in core? Is it a leftover?
  • what happened to the WPS part?
Simone Giannecchini
@simogeo
