[Geoserver-devel] GSIP 207, feature type info customization
+1, much easier than to play with schema.xsd and offers more features, especially for non-SQL data sources when a database view is not an option.
Maybe there could be a test button that tests if new names are valid in XML and if type casts are possible and/or lossless.
-Jukka Rahkonen-
Lähettäjä: Ian Turton <ijturton@…403…>
Lähetetty: keskiviikko 22. joulukuuta 2021 15.21
Vastaanottaja: Andrea Aime <andrea.aime@…6887…>
Kopio: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] GSIP 207, feature type info customization
All sounds good to me, only question that occurs to me is about the filter does this apply to the data coming from the datastore as now or the new data?
Ian
On Wed, 22 Dec 2021, 11:04 Andrea Aime, <andrea.aime@…6887…> wrote:
please read and discuss GSIP 207, proposing to make the feature type
attribute table editable and customizable, for simple features:
https://github.com/geoserver/geoserver/wiki/GSIP-207
Feedback and votes welcomed
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Geoserver-devel mailing list
Yes, that’s the main target.
Service validity checks would be a GSIP of their own, WFS is not necessarily active, and not necessarily used to serve data in GML
(I see installations where WFS is just a means to get GeoJSON for example).
Making sure the type casts are sensible is an interesting idea… conversion is performed via GeoTools Converter implementations,
which are pluggable. What I could do, is to add a check on whether a converter exists, that goes from the native type to the
target type, using Converters.getConverterFactories(source, target). However, I have no way to tell if the conversion
will be lossless, or not… maybe the feature type should be marked as read-only in that case, as there is no guarantee
the back-mapping would produce something sensible… on the other end, it might, and the mechanism would deny also
working situations.
What about documenting the issue, and letting the admin decide whether editing should be allowed, using the security
sub-system (there is no other way to make a feature type read only)?
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
