I would like to propose the addition of the possibility to configure fixed Time/Elevation values on the LayerConfiguration page to use them as Dimension metadata in the capabilities responses.
Please consider reviewing the proposal available here.
The improvement aims at improving performance of GetCapabilites request since currently multiple queries to the datasource needs to be performed in order to retrieve unique values or MAX and MIN values.
Marco Volpini
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Jody,
thank you for the feedback, this proposal is about the possibility of providing static metadata, not caching. This is needed for use cases where:
Even computing the min\max\period\list values once is too expensive, for example, a database with 10 billion records.
For data sources where the necessary aggregation operations are not available.
Regarding caching, is out of the scope of this proposal, but could indeed be a good future addition.
Kind regards,
Nuno Oliveira
Nuno Oliveira
