[Geoserver-devel] GSIP 210: graduate KML-PPIO to extension
I’ve prepared a GSIP to graduate the KML-PPIO module based on our discussion during the last PSC meeting, available here:
https://github.com/geoserver/geoserver/wiki/GSIP-210
Let me know what you think, and/or cast a vote if you’re on the PSC.
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
+1
Simone Giannecchini
Professional Support for GeoNode, GeoServer and MapStore from the experts!
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director GeoSolutions Italy
President GeoSolutions USA
US: +1 (845) 547-7905
http://www.geosolutionsgroup.com
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
Alessio Fabiani
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
I like the functionality, and the approach suggested to thread the needle between graduating as an extension and including as part of the wps distribution.
I do not like the name (“extension/kml-ppio” as it is not a distinct extension, and ppio is an internal abstraction to the codebase and not really something for the user guide).
Since it is intended to be distributed as part of “wps” extension, how about changing:
For this reason, we propose to graduate it with a more gradual approach:
  • The module, as code, would graduate to extension as its own extension/kml-ppio module
  • Packaging wise, it would be included in the wps release zip, making it transparently available to end-users without extra hassle.
To the following:
  • The module, as code, would graduate to extension/wps/wps-kml-ppio
This way it does not look like a downloadable extension.
Jody Garnett
Alessio Fabiani
@alfa7691
GeoSolutions Group
Done. Updating the location of the module in the PR (it is indeed a sensible place): https://github.com/geoserver/geoserver/pull/5771
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
+1, thanks Andrea
Jody Garnett
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I was going to ask if this included promoting the GeoTools kml module to supported but I see that it doesn’t use it. Is there a possibility to move the KML parsing and generating code back into GeoTools at some point in the future? It would be nice to have that functionality in a supported GeoTools module and avoid it being implemented twice in GeoServer (is it?)
Otherwise +1
Ian
Ian Turton
+1
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Technical Lead / Project Manager
GeoSolutions Group
The kml unsupported module is a datastore. While a PPIO can use such a high level API, it has no need to.
To draw a couple of parallels:
  • GeoJSONPPIO uses low level GeoJSONWriter and GeoJSONReader (it could be written against the stores, but it would be overkill, we just want to read features out of a stream, and encode them onto a stream)
  • ShapeZipPPIO uses a store, because it’s not harder than using a lower level API, we still need to dump on local filesystem first to zip
The parsing is already using gt-xsd-kml just like the GeoTools KML unsupported code.
The writing instead is using the GeoServer KML module, both for consistency and functionality. That code might not be
that is easy to extract, as it was written with usage in GeoServer in mind (depends in a lot of places on WMSMapContext/GetMapRequest).
The gt-xsd-kml module has also encoding support, but as most XSD modules, it’s not symmetric (one has to write parsing and encoding
as separate groups of methods, ability to parse does not equate to the one of writing, and vice versa).
I see the module has encoding tests, but don’t know how well it works… I recall Alessio had troubles making it work during the
first write of kmlppio, and eventually switched to the GeoServer kml module instead.
It’s good to have consistent behavior between WFS and WPS output formats… the other possibility would be to rewrite the
kml module to use gt-xsd-kml for encoding which… just gives me nightmares TBH!!!
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
That sounds like a very good plan then.
Ian
Ian Turton
+1
On 2022-04-01 07:06, Andrea Aime wrote:
== GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information. == Ing. Andrea Aime @geowolf Technical Lead
GeoSolutions Group phone: +39 0584 962313
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@anonymised.comsourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Kevin Smith
[smithkm@anonymised.com](mailto:smithkm@anonymised.com)
+1
Torben
On Fri, Apr 1, 2022 at 7:07 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
+1
Alessio Fabiani
@alfa7691
GeoSolutions Group
+1
Nuno Oliveira
@nmcoliveira
GeoSolutions Group
