[Geoserver-devel] GSIP 213 CSS Cleanup
Jody and Michel here from the Bolsena code sprint with a proposal for cleaning up the use of css:
https://github.com/geoserver/geoserver/wiki/GSIP-213
Scroll down to the bottom of the proposal for an example, feedback (and encouragement) welcome.
Jody Garnett
Hi Jody,
I’ve just skimmed through the proposal.
The idea of modernization and cleanup is nice, and needed.
The backwards compatibility breakage on custom CSS for the GeoServer UI less so, but I think they are not used very much, not particularly worried about it.
What gets me really worried though is that this is not just a geoserver.css change, but a wholesale change in all HTML files
to follow it:
  • I don’t see any visual indication in the proposal, does it mean the UI will look exactly the same? If not, do you already know what you’re going to change?
  • With just two developers, I don’t see how you can go over all extensions and community modules. If you simply intend to break all community modules, you should say so, it should be a prominent message in the proposal (they are not supported, but it does not mean they are not used, PSC will have to agree to take on the upgrade work that will follow, as it happened for the REST config API sprint for example). A reasonable approach would be to ensure old GUI modules do gracefully work even with the new CSS, and would also help cover customizations/plugins outside of the repository (plenty of them around).
  • Even limiting yourself to core and extensions, are you going to manually test before/after all the extension modules? Are you familiar with all of them?
  • Going through the HTML files you’ll have the temptation to just add other unrelated changes to “make things better”… but these are not really covered by the proposal. Can you resist the temptation?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Michel will comment tomorrow, but yeah no interest in adding anything or changing visual appearance. Such an idea would happen after a cleanup like this makes it possible.
If you are quite concerned about community modules the existing geoserver.css could stay in the mix for some year before being removed? Also for the community modules many of the html files everywhere are cut and pasted from other pages so I expect search and replace would be helpful.
But really Michel is the css expert and indicates this is “easy” and would like to make the improvement (after working on customer themes for some years now and being well aware of the scope of the challenge).
Jody
Jody Garnett
Hello Andrea,
I will try to explain a bit what I want to do.
• I will keep the UI the same as it is, I will replace hardcoded styles with proper classes that do the same.
• No new styling will be introduced
• The `geoserver.css` will stay, `bootstrap-utilities.css` will be added to provide extra styling possiblities for positioning purposes (padding, margin, left, right)
• The `bootstrap-utilities.css` will not affect current styles, it only adds some extra classes you can use, if you don’t use them nothing will happen
• When needed current styling (a combination of HTML/CSS) will be modified/modernised but the visual outcome will stay the same and if you don’t change HTML nothing will happen
• We know it can be a lot of work, but when done correctly, it doesn’t have to be done all at once. We can target some improvements per PR (the first PR will add the bootstrap css file though so we can continue on top of that)
• …and in all the years I’m doing this I learned to resist the temptation to add ‘unrelated things’ to just make things better :slight_smile:
If you need more information or have any more questions, please ask.
Kind regards,
Michel Gabriël
On 15 Jun 2022, 23:19 +0200, Jody Garnett <jody.garnett@anonymised.com>, wrote:
Jody
> On Wed, Jun 15, 2022 at 7:29 PM Andrea Aime <andrea.aime@anonymised.com> wrote:
> > Hi Jody,
> > I've just skimmed through the proposal.
> > to follow it:
> > • I don't see any visual indication in the proposal, does it mean the UI will look exactly the same? If not, do you already know what you're going to change?
> > • With just two developers, I don't see how you can go over all extensions and community modules. If you simply intend to break all community modules, you should say so, it should be a prominent message in the proposal (they are not supported, but it does not mean they are not used, PSC will have to agree to take on the upgrade work that will follow, as it happened for the REST config API sprint for example). A reasonable approach would be to ensure old GUI modules do gracefully work even with the new CSS, and would also help cover customizations/plugins outside of the repository (plenty of them around).
> > • Going through the HTML files you'll have the temptation to just add other unrelated changes to "make things better".. but these are not really covered by the proposal. Can you resist the temptation?
> > Cheers
> > Andrea
> > > On Wed, Jun 15, 2022 at 3:25 PM Jody Garnett <jody.garnett@anonymised.com.> wrote:
> > > > Jody Garnett
> > > > _______________________________________________
> > > > Geoserver-devel mailing list
> > > > Geoserver-devel@lists.sourceforge.net
> > > > https://lists.sourceforge.net/lists/listinfo/geoserver-devel
> > Regards,
> > Andrea Aime
> > Ing. Andrea Aime
> > @geowolf
> > Technical Lead
> > GeoSolutions Group
> > http://twitter.com/geosolutions_it
Jody Garnett
Hello Andrea,
Jody and me just reviewed the proposal and changed some text for a better understanding of what I plan to do.
Kind regards,
Michel Gabriël
On 16 Jun 2022, 11:04 +0200, Michel Gabriel <michel.gabriel@anonymised.com>, wrote:
Hello Andrea,
Kind regards,
Michel Gabriël
> Jody
> > Hi Jody,
> > to follow it:
> > Cheers
> > Andrea
> > On Wed, Jun 15, 2022 at 3:25 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
> > > Jody Garnett
> > > Geoserver-devel@anonymised.com://lists.sourceforge.net/lists/listinfo/geoserver-devel
> > Regards,Andrea Aime==GeoServer Professional Services from the experts!Visit http://bit.ly/gs-services-us for more information.==
> > Ing. Andrea Aime
> > @geowolfTechnical Lead
> > GeoSolutions Groupphone: +39 0584 962313fax: +39 0584 1660272mob: +39 333 8128928
> > https://www.geosolutionsgroup.com/http://twitter.com/geosolutions_it-------------------------------------------------------
> Jody Garnett
Love to hear it's going to be progressive and pages based on old and new
can coexist.
Also like to see the QA checks to prevent further regressions! What tools
do you plan to use to run the tests?
I see PMD can be used to avoid inline styles
<https://pmd.github.io/latest/pmd_rules_html.html&gt;, fits the bill,
although the overall list of rules is really small... Maybe you have
something better in mind?
On Thu, Jun 16, 2022 at 11:04 AM Michel Gabriel <michel.gabriel@anonymised.com>
wrote:
Hello Andrea,
   - I will keep the UI the same as it is, I will replace hardcoded
   - No new styling will be introduced
   - The `geoserver.css` will stay, `bootstrap-utilities.css` will be
   - The `bootstrap-utilities.css` will not affect current styles, it
   will happen
   - When needed current styling (a combination of HTML/CSS) will be
   - We know it can be a lot of work, but when done correctly, it doesn’t
   of that)
   - …and in all the years I’m doing this I learned to resist the
Kind regards,
Michel Gabriël
helpful.
Jody
Hi Jody,
about it.
to follow it:
   - I don't see any visual indication in the proposal, does it mean
   going to change?
   - With just two developers, I don't see how you can go over all
   - Even limiting yourself to core and extensions, are you going to
   all of them?
   - Going through the HTML files you'll have the temptation to just add
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
And oh... +1
On Thu, Jun 16, 2022 at 12:52 PM Andrea Aime <
can coexist.
On Thu, Jun 16, 2022 at 11:04 AM Michel Gabriel <michel.gabriel@anonymised.com.>
wrote:
Hello Andrea,
   will happen
   top of that)
Kind regards,
Michel Gabriël
helpful.
Jody
Hi Jody,
about it.
to follow it:
   going to change?
   all of them?
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
I was going to use code style like we check for headers? Suggestions welcome.
Jody Garnett
The headers are checked by checkstyle.. but it's designed only for Java
code AFAIK:
https://checkstyle.sourceforge.io/
One related thing that I've been looking into is to use spotless to also
format XML and HTML files,
but found I wanted to configure the formatter and that is problematic in a
multi-module build:
https://github.com/diffplug/spotless/issues/1135
May not be of interest to you right now, but thought I'd throw it out there
anyways.
On Thu, Jun 16, 2022 at 1:18 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
welcome.
Jody Garnett
On Thu, 16 Jun 2022 at 12:52, Andrea Aime <
can coexist.
michel.gabriel@anonymised.com> wrote:
Hello Andrea,
   will happen
   top of that)
Kind regards,
Michel Gabriël
helpful.
Jody
Hi Jody,
about it.
to follow it:
   going to change?
   all of them?
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
This is definitely a part of GeoServer that could use cleanup.
I would request that this effort include documentation of HTML/CSS best practices in the developer guide (matching the changes that were made). Probably somewhere in this subsection.
This should help existing developers navigate the changes, and help keep future additions to the Web GUI in-line with the modernized structure.
Torben
On Wed, Jun 15, 2022 at 6:25 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
+1 and +1 to Torben’s suggestion
Ian
Ian Turton
Yup, excellent idea!
I cannot talk about others, but much of my HTML writing is at the “monkey see, monkey do” level… so I’d appreciate having some guidance :smiley:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
+1 Thanks this looks like quite a lot of work but for sure it’s worth it.
Alessio Fabiani
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
mob: +39 331 6233686
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
