+1 for dropping Java 8 for GeoServer 2.23.0.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett jody.garnett@anonymised.com
Lähetetty: keskiviikko 31. elokuuta 2022 12.21
Vastaanottaja: Andrea Aime andrea.aime@anonymised.com
Kopio: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] GSIP-215 Drop Java 8
Okay, updated proposal to target dropping Java 8 for GeoServer 2.23.0.
Jody
On Wed, Aug 31, 2022 at 10:34 AM Andrea Aime <andrea.aime@anonymised.com> wrote:
+1 on switching to Java 11 only on main, I’m between a -0 and a -1 on dropping on 2.22.0 too.
Dropping Java 8 support in 2.22.0, as it would give the user base only 6 months before GeoServer stops supporting Java 8 altogether
(2.20.x is about to get its last release, 2.21.x will live only up to March 2023).
The 2.21.0 release already contained a warning, quoting:
“This is likely to be the last release that supports Java 8 and we encourage users to start to make the transition to Java 11 during the lifetime of this branch.”
The message was too easy to ignore IMHO, I’d prefer to have a 2.22.0 with a title stating in unequivocal terms “This is the last release supporting Java 8, upgrade now”.
On Tue, Aug 30, 2022 at 8:15 PM Jody Garnett <jody.garnett@anonymised.com3…> wrote:
Please see https://github.com/geoserver/geoserver/wiki/GSIP-215 for details, general idea is to drop Java 8 support so we can update dependencies and plan Jakarta migration.
Thanks to foss4g code sprint and Euan Mitchell for initial pull request for docs:
If this proposal is ready for the 2.22.0 release it would simplify the process of setting up build jobs for the new release cycle. Vote early, vote often…
Jody Garnett
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Andrea Aime
GeoServer Professional Services from the experts!Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions Group
phone: +39 0584 962313fax: +39 0584 1660272
mob: +39 339 8844549
Jody Garnett
