so the GSIP work has been merged on main. Which will be released in September.
As a breaking change, backport as-is may not be an option (with checkers enabled by default).
But we might backport, with checks disabled, and suggest users to enable them and configure accordingly.
What do you think?
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Can we consider being a bit more forthright “on by default” with security things; as it is too easy for folks with long running implementation to not keep up with best practice.
Backport with the improvement added and a clear security consideration section calling out the new functionality.
I know our policy is to make stable l, and especially maintenance releases, preserve existing workflow. In this case I think the safety improvement is worth asking admins to pay attention. Security is special
Aside: it is probably time to enabled the entity resolution allow list by default.
Hmm… nope, if the direction was to have it enabled by default, I’d consider waiting for September instead.
Let’s backport with disabled as default, mark the release blog for security consideration, and tell people to enable and configure instead?
While security is important, we don’t want people not upgrading at all because we’ve broken their configs. This path still gets the security patch in for those who need it, but doesn’t break any existing systems.
