[Geoserver-devel] GSIP 219: Multiple CRS authority support, planetary CRS
the following proposal aims to add support for authorities other than EPSG
in selected parts of GeoServer, and provide a working example based on the
IAU authority (planetary CRSs).
https://github.com/geoserver/geoserver/wiki/GSIP-219
Key points:
  • It’s not trying to address all places where EPSG authority assumptions are made, but provides a specific list instead. Other cases can be handled later as bug fixes, as funding comes to fix those as well.
  • Discusses a couple of way to plug in other authorities (can you suggest more/better ones?).
    Feedbacks/votes welcomed!
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
I assume that some/much of this work will be in the GeoTools tree?
As for how to package this on the one hand I like the simplicity of a new extension, it’s easy for users to understand and provides a good way to keep track of versions, on the other hand it’s easy to forget to add it on upgrade and break all your layers. Just thinking aloud here, how much effort would it be to get the existing authority discovery code (or are they hard coded) to “discover” new authorities by looking in a “well known” location?
Anyway +1 for the general plan, looking forward to seeing the details
Ian
Ian Turton
It’s evenly split between GeoTools and GeoServer.
SPIs tend to be hard-coded, you can have only one instance of each class registered, which tends to favour
an approach based on modules, each one having its WKT authority factory subclass.
What I may be able to do get away with, in order to support files discovered in the data directory, is to use
bytecode engineering to create the new subclasses on the fly.
90% of it is really going to be specific bug fixes in the places making the EPSG assumptions,
I have a laundry list of things and will likely discover more as I work on it (hence the strict scope control,
I have a contract backing this, not a charity).
The only truly new bit will be the support for the IAU authority.
That said, as a “thing” it’s big enough that I thought I would write a proposal anyways.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
+0
Nuno Oliveira
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Technical Lead / Project Manager
GeoSolutions Group
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
+1
The proposal has EPSG as the defacto spatial reference system authority, we also have CRS and AUTO somewhere in the mix …
The proposal identifies a number of areas that will be included in scope; one I was interested in was not covered. The ability to limit the srs published by WMS is a common configuration - although not in scope I assume it could be covered by allowing: IAU2000:49900,IAU2000:49901
I honestly do not know how it works for the top-level srs list if there are a mix of earth layers and planetary layers in a WMS - perhaps it should be empty?
Thanks for the proposed improvement,
Jody
Jody Garnett
+1
Correct, although they only work in specific use cases.
It’s not in scope, but I will try to sneak it in, if I manage to work below the allocated timebox. No promises though.
Not really… we already have plenty of incompatible combinations by mixing local and global SRSs, that will fail if tried. Testing what’s compatible
would make the time for generating the caps balloon, but also, the area of definition of SRSs is going to be missing from WKT based systems,
and when available is useful only from a bureaucratic point of view, it’s often way too tight for cross-border projects.
Long story short, behavior will be just like now, GeoServer is going to list what it has, and will eventually fail if an incompatible mix is chosen.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
Clarification: I am not trying to put it in scope; just understand if we have a decent plan in mind if capacity shows up in the future :slight_smile:
Cool; as above - just trying to understand how it fits together. It could be that these layers would be best handled as a virtual web service (if we really need accurately restricted capabilities).
Jody
Ok. I’ll try to sneak it anyways, if I can :smiley:
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
