Hi Jody,
the plan looks good to me, what I’m missing right now is how you get there.
During the meeting it was said you’re working one section at a time, at a superficial level
it seems half of them are still to be covered: https://jodygarnett.github.io/geoserver/
Each section might hold surprises. So wondering if you need help and who’s up to do so
(calling myself out here, using the little I have to get the wicket upgrade to completion…
besides I can do python only when chatgpt writes it for me ).
Jody Garnett
Andrea Aime
I asked for some help when we go live to troubleshoot deploy as that is not something we can test ahead of time.
I was stuck on downloads for a while (this is also not an urgent activity for me).
Now that I am unstuck it is manual work doing a section creating the page navigation tree, repeat. I should have probably made a script for the nav tree creation.
I am being pragmatic in fixing broken relative links and so on in the RST docs (rather than try and make the script robust).
Jody Garnett
Jody Garnett
Andrea Aime
