Thanks to Krishna Lodha (rottengrapes.tech) for woking on this proposal with me.
Our policy is to hold voting open for ten days (December 29 th), given that many people are occupied with the festive season I will keep this proposal open until January 3rd.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
A reminder that this is held open until next week Given how quiet it is we may need to hold it open until Jan 5th.
If you have not done looked at the proposal recently I now have 95% of content converting okay, even the tricky ones like literalinclude and include etc…
I also got some “geoserver theme” aspects to work with both light and dark mode.
Some work remains, some trouble with nested directives, specifically block directives in block directives as seen here:
