Hey all,
I would like to open GSIP 29 for feedback/voting.
http://geoserver.org/display/GEOS/GSIP+29-+GeoSearch+Index+Exposure+in
+GeoServer
David Winslow
OpenGeo - http://opengeo.org/
Hey all,
+GeoServer
David Winslow
Hi David,
Some of the formatting seems a bit off on that page.
A couple of questions. In terms of the code base what does this entail? Moving rest and geosearch modules to core? What is the current test coverage of those modules?
-Justin
David Winslow wrote:
Hey all,
+GeoServer
Justin Deoliveira
On Thu, 2009-01-15 at 09:23 -0700, Justin Deoliveira wrote:
Hi David,
Thanks for catching this, fixed on the wiki.
Added these q&a's to the wiki, copying here for convenience:
Jdeolive: In terms of the code base what does this entail? Moving rest
The geosearch module depends on the rest module, so both need to be
available, yes.
Jdeolive: What is the current test coverage of those modules?
rest: 46%
geosearch: 49%
-Justin
> Hey all,
> +GeoServer
David Winslow
Cool, thanks David. Taking another read over it the proposal is for an extension, whereas I was under the impression that it would be a core module?
Also it would be nice if the proposal linked to any available docs on how to use the geosearch stuff.
-Justin
Hi David,
and geosearch modules to core?The geosearch module depends on the rest module, so both need to be
available, yes.Jdeolive: What is the current test coverage of those modules?
rest: 46%
geosearch: 49%
-Justin
Hey all,
+GeoServer
Justin Deoliveira
module?
At the time of writing I was concerned that the userbase for the module
was not enough for core status; however, after reviewing GSIP 22 I see
that there is no distinction in the requirements for core modules versus
supported extensions (and geosearch does have the required number of
users). I will update the proposal to reflect this.
Adding this as well. Again, link for convenience:
http://geoserver.org/display/GEOS/GeoSearch+Module
-Justin
>> Hi David,
> available, yes.
> rest: 46%
> geosearch: 49%
>> -Justin
>>> Hey all,
>>> +GeoServer
David Winslow
Looks good David. So i am +1 on this. Hopefully we can get enough votes in by Monday to include it in the 1.7.2 release :).
users). I will update the proposal to reflect this.Also it would be nice if the proposal linked to any available docs on how to use the geosearch stuff.
Adding this as well. Again, link for convenience: http://geoserver.org/display/GEOS/GeoSearch+Module
-Justin
Hi David,
rest: 46%
geosearch: 49%
-Justin
Hey all,
+GeoServer
Justin Deoliveira
