[Geoserver-devel] GSIP 32, moving rest from community to core
Here is the official proposal for moving the rest module to a core module.
http://geoserver.org/display/GEOS/GSIP+32+-+REST+support+module
Feedback welcome.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Justin Deoliveira ha scritto:
Feedback welcome.
The documentation page is leaving me with some doubts. Like, for example, the role of a finder in our implementation. Do we have any?
The example does not show how to deal with output formats other
than plain text. Is this still working based on maps, or based
on reflection?
It would also be nice to see some javadocs, probably they would
answer the above questions.
Andrea Aime
Feedback welcome.
The docs are a bit basic at this point. They need some work. I will expand on them. But essentially the finder is used to map different classes of resources, to a single url. And that is just my practical understanding... David probably has better insight since he knows restlet better than I.
on reflection?
Yeah, the example there is based on the most simple thing one can do. Again, I will expand on the docs but essentially there are subclasses of AbstractResource: MapResource, and ReflectiveResource, which can do some automatic serialization for you in json and xml. My plan was to add three tutorials... 1) the very basic 2) the map approach 3) the reflection approach
Added a link from the proposal. But they are available here:
http://gridlock.openplans.org/rest/apidocs/
Justin Deoliveira
I added two sections to the developer documentation. One is an example of how to build a service/resource with the map based approach. The other is how to build a service/resource with the reflection based approach. Here is the link again:
http://gridlock.openplans.org/geoserver/1.7.x/doc/developer/programming-guide/rest-services/index.html
-Justin
Justin Deoliveira wrote:
Feedback welcome.
on reflection?
Justin Deoliveira
I am enjoying the documentation thus far; can I confirm that we are talking about moving the rest “displatch” code into core; similar to how the ows dispatch code is in core already? ie. “resut support module” is about enabling REST support; and does not expose any rest services on its own?
Jody
PS. I like the look of the new docs; although I miss the maven and eclipse quickstart information which I have handed out to new developers a couple times in the last month
On Fri, Feb 6, 2009 at 3:28 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
module.
http://geoserver.org/display/GEOS/GSIP+32±+REST+support+module
Feedback welcome.
understanding… David probably has better insight since he knows
on reflection?
three tutorials… 1) the very basic 2) the map approach 3) the
reflection approach
Justin Deoliveira
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR™
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com
Geoserver-devel mailing list
The short answer is, no, the rest support module doesn't expose any rest
services.
The longer, but more technically accurate answer is that it does expose
one endpoint; that being an index page which lists all non-parameterized
REST pages. The idea is that you can find out what services are
provided and, if the developers have made the effort to keep them
HTML-friendly, navigate them through the browser.
David Winslow
OpenGeo - http://opengeo.org/
talking about moving the rest "displatch" code into core; similar to
how the ows dispatch code is in core already? ie. "resut support
module" is about enabling REST support; and does not expose any rest
Jody
        example
        approach. The
        based
        -Justin
        > Andrea Aime wrote:
        >> Justin Deoliveira ha scritto:
        >>> Hi all,
        >>> Here is the official proposal for moving the rest module
        to a core
        >>> module.
        >>> http://geoserver.org/display/GEOS/GSIP+32+-+REST+support
        +module
        >>> Feedback welcome.
        >> The documentation page is leaving me with some doubts.
        Like, for
        >> example, the role of a finder in our implementation. Do we
        have any?
        > The docs are a bit basic at this point. They need some work.
        I will
        > expand on them. But essentially the finder is used to map
        different
        > classes of resources, to a single url. And that is just my
        practical
        > understanding... David probably has better insight since he
        knows
        > restlet better than I.
        >> The example does not show how to deal with output formats
        other
        >> than plain text. Is this still working based on maps, or
        based
        >> on reflection?
        > Yeah, the example there is based on the most simple thing
        one can do.
        > Again, I will expand on the docs but essentially there are
        subclasses of
        > AbstractResource: MapResource, and ReflectiveResource, which
        can do some
        > automatic serialization for you in json and xml. My plan was
        to add
        > three tutorials... 1) the very basic 2) the map approach 3)
        the
        > reflection approach
        >> It would also be nice to see some javadocs, probably they
        would
        >> answer the above questions.
        > Added a link from the proposal. But they are available here:
        > http://gridlock.openplans.org/rest/apidocs/
        >> Cheers
        >> Andrea
        Justin Deoliveira
        Adobe(R)AIR(TM)
        skills and code to
        the power of local
        Adobe AIR SDK and
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Thanks for the clarification (I am glad I understood the proposal correctly). It sounds like you are working through the documentation issues as they arise; I am in favor of the technical direction so this proposal gets a +1 from me.
Jody
On Mon, Feb 9, 2009 at 2:04 PM, David Winslow <dwinslow@anonymised.com> wrote:
The short answer is, no, the rest support module doesn’t expose any rest
services.
David Winslow
Jody
example
approach. The
based
-Justin
to a core
module.
+module
Feedback welcome.
Like, for
have any?
I will
different
practical
knows
other
based
on reflection?
one can do.
subclasses of
can do some
to add
the
reflection approach
would
Justin Deoliveira
Adobe(R)AIR™
skills and code to
the power of local
Adobe AIR SDK and
Hi guys, here Alessio++
Cheers.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 980933
fax: +39 0584 983027
mob: +39 349 8227000
On Tue, Feb 10, 2009 at 1:25 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
gets a +1 from me.
Jody
services.
David Winslow
> Jody
> example
> approach. The
> based
> -Justin
> >>> Hi all,
> to a core
> >>> module.
> +module
> >>> Feedback welcome.
> Like, for
> have any?
> I will
> different
> practical
> knows
> other
> based
> >> on reflection?
> one can do.
> subclasses of
> can do some
> to add
> the
> > reflection approach
> would
> >> Cheers
> >> Andrea
> Justin Deoliveira
> Adobe(R)AIR(TM)
> skills and code to
> the power of local
> Adobe AIR SDK and
> Adobe(R)AIR(TM)
> code to
> local
> and
Adobe(R)AIR(TM)
to
local
Sorry for the late feedback. Docs look very nice now :slight_smile:
+1 on the proposal for me
Andrea Aime
