[Geoserver-devel] GSIP 33: rest configuration, call for vote
So far feedback has been mostly positive from Andrea. And I added a reference to the http specifications description of the various status codes as per his request, so I assume that is a +1?
Jody's feedback has mostly been about core catlog stuff, so I think a bit out of scope. Most of which will be brought up again when we work toward the data publishing split that has been proposed for 2.x.
So others, any feedback? Or can i assume silence == positive vote? :wink:
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Hi Justin,
sorry fot the delay ... I didn't send any feedback until now since I
had no chance to take a deep look at the work done and at the actual
rest interfaces status.
The last time I tried to compile the rest module I wasn't able to
handle rasters via Rest interfaces anymore at least so I promise
myself to spend some time on that ... however I am very positive to
the GSIP 33 proposal.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 980933
fax: +39 0584 983027
mob: +39 349 8227000
On Fri, Feb 27, 2009 at 8:37 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
-Justin
Justin Deoliveira
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
http://p.sf.net/sfu/XcvMzF8H
Geoserver-devel mailing list
Hi Alessio,
I am not sure when you last tried it out, but there are some test cases which upload raster data. Also I have written some scripts which are capable of complete re-creating a release data directory from scratch. So perhaps updating and trying again might do the trick? Although it is quite possible that the re-implementation has missed your specific case. Any chance you could provide a quick example of what you need to do?
Alessio Fabiani wrote:
Hi Justin,
Via Carignoni 51
55041 Camaiore (LU)
-Justin
Justin Deoliveira
Justin Deoliveira
I agree Justin; my feedback is based on asking where we want to take this. With that in mind are the urls as defined going to stay that way?
If we can answer yes (or if we answer that we can work with the way things are) my vote is +1.
Jody
On Sat, Feb 28, 2009 at 6:37 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Jody’s feedback has mostly been about core catlog stuff, so I think a
-Justin
Justin Deoliveira
