[Geoserver-devel] GSIP 34, call for vote
I would like to call for a vote on GSIP 34:
http://geoserver.org/display/GEOS/GSIP+34+-+New+data+directory+structure+for+2.x
Most feedback as been incorporated but the proposal of adding the idea of maps into the picture has not been incorporated for now. The reasons why being:
1) It increases scope in the short term without a lot of gain. Since the the upgrade to including maps into the picture is strictly additive to the data directory structure, it won't be an issue to add it later. Implementing maps in the short term, even just creating the idea of a default map is not trivial, and adds a pretty big hurdle.
2) Andrea pointed out that the data publishing split with regard to maps has not totally been fleshed out at this point. And indeed there is some thoughts about using a thread local view of the catalog as an alternative. So adding in maps to the structure now could indeed be a crutch come later.
So that is the rationale for leaving it out of the picture for now. Those who stand by the feedback still can vote -1.
So with that said, let the voting begin.
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Thanks for the nice clear presentation - I am happy to vote +1.
I would consider:
global.xml
service/wfs.xml
service/wms.xml
service/wcs.xml
service/wps.xml
But it does not make much of a difference.
Jody
On Wed, Mar 18, 2009 at 6:17 AM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
why being:
crutch come later.
-Justin
Justin Deoliveira
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
Geoserver-devel mailing list
Hi
I'm just consulting my team on this - but I'd make two comments
1) agree with Jody - if services are "plugged in", having hard coded
top level file names for config seems wrong. Can we change this to a
more explicit
services/<unique service plugin name>.xml
so that it can be extended without further negotiated change to the
formal structure?
2) We are still burying database connections deep, and not re-using
them. I'd like database connections and other local configuration to
be normalised and re-used.
can we have a top level directory connections/ or authorisations/
This is a real issue when we distribute a re-usable Geoserver
configuration via version control - with multiple geoservers
delivering common stuff - INSPIRE for example would require this.
There may be an element of local mapping - but we actually found that
was often encapsulated in database views and it was only multiple,
buried, not-separately-testable database connections that needed
configuring.
3) It is important that namespaces be "augmented" by explicit
declaration - the general case is that the target configuration
exposes a namespace as part of a contract between the service and the
world of clients. It should be possible to "make this up" during
FeatureType configuration, or use one extracted from the definition of
the FeatureType (the application schema case). Its not clear to me if
this is an issue - probably an implementation issue, not a directory
structure issue
Sorry to provide feedback so late.
Rob Atkinson
On Wed, Mar 18, 2009 at 10:40 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
I would consider:
global.xml
service/wfs.xml
service/wms.xml
service/wcs.xml
service/wps.xml
Jody
why being:
crutch come later.
-Justin
Justin Deoliveira
Ah you miss understand me; we are discovery the services in code form;
as such we do not need a folder to straighten all the individual
service files out.
I expected to see a service/ folder but it is not strictly needed.
Jody
Rob I think that you have the option of using your container to manage
the database connections. As such if you want a single place to manage
connections you could look to your application server?
Okay I see how that makes it harder to just backing on to your
application server for connection pools etc.
Jody
On Wed, Mar 18, 2009 at 11:51 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
service files out.
I wasnt calling you a Miss!
I know we are discovering services - but if this is an extensible
mechanism, why not set up a naming convention so every new file doesnt
need a modification to the agreed structure (I reckon specifically
named files in the top level should be used sparingly, and under
control of the proposal, since documentation will need to be kept up
to date etc)
Good point - makes the argument for removing the database connections
from the guts of the config even more compelling IMHO!
yes - no guarantee that the application server will provide this either.
Rob
Hi Rob,
Thanks for the feedback, comments inline.
Rob Atkinson wrote:
Hi
more explicit
formal structure?
I am ok with putting these files in the services directory but whether they are at the top level or in a sub directory really makes no difference to how they will be read. The existence of the file does not mean the service is active, and vice versa.
configuring.
While I agree with the concept I want to reinforce that this proposal is not proposing any improvements to the configuration, and is not proposing any new information to be stores in the dat directory. It is just a reorganization of the information that is already there.
We don't store this info in config today so this is out of scope.
structure issue
You lost me on this one :).
Rob Atkinson
I would consider:
global.xml
service/wfs.xml
service/wms.xml
service/wcs.xml
service/wps.xml
Jody
why being:
crutch come later.
-Justin
Justin Deoliveira
Justin Deoliveira
Understood - it wasnt about the functionality, but simply not setting
a number of particular services in stone and needing changes to
directory structure to add any more (a top level file is part of
directory structure according to the scope of this request)
configuring.
OK - so if this is not going to make it harder to fix this later, you
have my +1 officially.
structure issue
Manually defining namespaces during configuration is a corner case in
the long run. These will always be defined in application schemas, or
can be generated automatically without user configuration if they have
no external meaning. So, just want to avoid putting too much effort
into something I think needs fixing.
Rob Atkinson
I would consider:
global.xml
service/wfs.xml
service/wms.xml
service/wcs.xml
service/wps.xml
Jody
wrote:
why being:
crutch come later.
-Justin
Justin Deoliveira
development
development
Justin Deoliveira
Cool, sounds good, services directory it is.
configuring.
structure issue
Ahh I see, and yeah I fully agree. This is the motivation behind the workspace idea, have it be a container for data stores, etc... and have a namespace just be an attribute of a feature type. Ideally the way it would work is as you say, upload a bunch of application schemas, figure out the application schema namespaces, and choice one when setting up a feature type.
Rob Atkinson
I would consider:
global.xml
service/wfs.xml
service/wms.xml
service/wcs.xml
service/wps.xml
Jody
wrote:
why being:
crutch come later.
-Justin
Justin Deoliveira
development
development
Justin Deoliveira
Justin Deoliveira
Hi all. I know I'm very late to the party here, so please forgive.
I like this proposal. It makes the directory more complex (in terms of quantity of files) but also more granular. That's a trade off I'm comfortable with.
The GSIP page doesn't seem to mention (or at least I can't find) the directory called "data" (either in the new schema or the old). Does this directory (which as we all know contains the actual shapefiles) still exist in the same place or has it been moved?
I ask because this highlights something uncomfortable for me: The Data Directory isn't really a data directory. What I mean is that it is both a Configuration Directory _and_ a Data Directory. And, also personally, I find it confusing (and so have some others) to have a "data" directory inside of the "Data Directory", especially when there are other things inside the "Data Directory" that aren't data. (Whew.) Perhaps this is just a nomenclature issue. (Jumping the gun here, I guess perhaps I'm asking that if we want to change the structure of the "Data Directory", perhaps it's a good time to change the name of it as well.)
Can anyone direct me through this? :slight_smile:
Mike Pumphrey
Justin Deoliveira wrote:
-Justin
Hi Mike,
You are very correct, the "data directory" is poorly named to the purpose it actually serves. But this is what it has always been called so I fear trying to rename or rebrand it woudl cause more confusion.
But you are right, calling it "GEOSERVER_CONFG_DIRECTORY" would make much more sense imo. And calling the "data" directory under the config directory the actual "data directory".
And about the "data" directory, it is the same in the new as in the old. I simply forgot to add it.
-Justin
Mike Pumphrey
-Justin
Justin Deoliveira
Hi Justin. Thanks for the clarification.
I understand that we're trying to minimize confusion, which is good. However, since are making so many changes with this GSIP, if ever there were a time to change names of things (major release and all), now would be the time.
So, I'd like to propose changing the name of the Data Directory. Just because it's always been this way doesn't mean it always should be this way! (I'm saying this so strongly just to elicit passionate feedback from people. :slight_smile: )
Caveat: This isn't (just) because it pains me to tell people to look in the data directory of their Data Directory. But think how nice it would be (especially for a new user) to say "look in the data directory inside your GeoServer Configuration Directory." Breathe out.
Mike Pumphrey
Hi Mike,
-Justin
Mike Pumphrey
-Justin
Hi guys,
a +0 on my side since it seems very good to me but I'm not deeply
involved in the 2.x development.
The only thing I can say is that it would be really nice to have at a
certain point a sort of "lazy" catalog or some mechanism which allow
us to persist/load only the things we are asking for, and as far as I
understood from the GSIP page this is one of the goals of this new
directory structure.
           Alessio.
Eng. Alessio Fabiani
Vice-President /CTO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584 980933
fax: +39 0584 983027
mob: +39 349 8227000
be the time.
Mike Pumphrey
Hi Mike,
-Justin
comfortable with.
Mike Pumphrey
reasons why being:
crutch come later.
-Justin
development
Hi Alessio,
Yeah, this is something I would love to see too. However doing lazy loading with the in memory catalog could be a lot of work. But def something that is needed for sure.
My unofficial plan has always been to handle this with the hibernate based catalog.
-Justin
Alessio Fabiani wrote:
Hi guys,
           Alessio.
Via Carignoni 51
55041 Camaiore (LU)
be the time.
Mike Pumphrey
Hi Mike,
-Justin
comfortable with.
Mike Pumphrey
reasons why being:
crutch come later.
-Justin
development
Justin Deoliveira
