Hi Justin (hey all),
here is the (in)famous file by file patch review :-p
General
* Most classes seem to miss the GeoServer license headers. This should
be addressed
before committing
* How are Hibernate lazy initializations and proxies managed? As far
as I can see
* Following up on the synchronization blocks inside the catalog: yeah,
we'd definitely need transactions if we want that to work fine also in memory.
Hibernate catalog wise we could use an "open session in view"
approach and just
have a servlet filter open the session and a transaction for us
without having to
roll a catalog transaction api.
The current setup, with transaction marked on the dao
implementations (via annotations)
is not going to work fine, the synchronization in the catalog does
not give any guarantee
that the changes are going to occur properly on the db. For example,
if the network goes down during one of those synch blocks and just
one of the dao commands
were sent away, well, bye bye, you'd get your database in an
inconsistent state.
I'd say this one is the only really serious problem I've seen in the
review, and one that should
be addressed with some urgency (if we go for a "open session in
view" approach it should not
be too hard to address too).
* I see some code trying to handle a migration from file based to datbase based.
Where is the migration happening? I see HibGeoServerLoader loading all of
the information from the old catalog, but how is that stored back in the db?
Details details
* The dbconfig pom seems to have a number of commented out dependencies.
A quick cleanup seems in order.
* in AbstractHibDao.first(query, doWarn) the doWarn param is not really used
to control exception reporting, an exception is always thrown
* In the same method there is some paranoid logging that was probably useful
only to the developer during the building of the class? At least
it's odd to see it
only there and not, for example, in list(query)
* HibPostLoadEventListener has an unused field, appContext
* FilterType uses XML encoding to store the filters. I'm wondering, what happens
if we have an idfilter mixed with other filters? Official encoding
does not support
that case, but we're good as long as we can round trip that case in
xml somehow.
ECQL could be another candidate for filter storage (but it has problems with
field names in other locales, which I guess is not the case for xml encoding)
* ClassMappings implementation looks odd to me.... why not use two fields and
create a class mapping with a WORKSPACE(WorkspaceInfo.class,
WorkspaceInfoImpl.class)
instead of using a raft of inner classes? Would seem simpler to
implement, easier to read,
and use less bytecode in the end
* persistence.xml has a commented out block about the mapping file
* dbConfig own applicationContext.xml hard codes the references to a H2 database
located in the data directory. Is this going to become configurable
so that one can
point GeoServer to an external database without the need to unpack the jars,
modify the files, pack them again and restart?
* in mappings.hbm.xml there is a ton of " <!--cache usage="read-write"/-->"
What is going on there?
There is also a mappings.hbm.xml.orig which should not be there long term wise
* the github diff contains a "community/monitoring/GeoLiteCity.dat"
file that should
not be there (btw, is that a geolocation database? )
* The patch set contains a H2 dialect. As far as I can see here:
http://opensource.atlassian.com/projects/hibernate/browse/HHH-3401
in 3.3.2 the H2 dialect was finally fixed. Maybe this class is no
longer needed?
Closing up
Most of the feedback above is on secondary importance details, meaning the
overall setup is good
The current transaction management worries me, I'm not saying it has to be
improved right now but it should at least be put at some high priority
in the near
future, before we start advertising that we have a "rock solid" db storage for
catalog and configuration
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
