On Fri, Oct 14, 2011 at 7:37 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
I have been working trying to organize the wfs 2.0 work into a proposal ready state and here is the result:
http://geoserver.org/display/GEOS/GSIP+61+-+WFS+2.0
Patches linked from the proposal. Thoughts and feedback welcome.
Massive. Let me start with something easy, reading the proposal and
discussing it (patches...later)
* Services Architecture -> ok
* Request Object Model -> cool
* Filter 2.0 -> yep
* Paging -> cool, two observations (not blocking or anything, just
related stuff that might be of interest)
The work I did on trunk for the aggregating data store actually allows
any store to implement sorting,
and subclasses of content data store get that for free.
The other interesting bit is that the code doing merge-sort can dump
features on the disk quickly
enough (using other serialization technologies it could be made faster
though), this could be used
to actually dump an entire result set on disk for real stable paging.
It is just an idea, and if implemented, imho it should be something
that the administrator has to
enable explicitly, setting a max feature for WFS carefully in
accordance to avoid killing the
disk in the process.
* Joins -> nice, one question here
Is the client able to know in advance which two types can be joined?
Does the standard foresee the option of seletively supporting joins
only on some feature types?
* Stored query -> cool (/me dreams of stored ECQL)
* Soap -> ok, with questions
Say a response is not XML and does not implement the SOAPAwareResponse
interface... what happens?
Also, do we have everything soap-ified by default? Like, is WCS/WPS
going to receive
the SOAP magic as well? Or do we have to implement something specific?
Another question is... where are the WSDL coming from?
* Extended operators -> ok (we are going to have a ton of extended ops
out of the box!)
* Backwards compatibility -> yep, the usual drill. Meh, one day we
should allow the administrator
to choose what the default version of each protocol is.
Tomorrow I'll try to have a look at the patches too
One remaining thing I failed to do was to run the wfsv tests. I tried setting up the database and the fixture locally to run the tests but still failed. It seems LegacyDbmsTestData.getDatabaseConnection() is unable to get the underlying connection from the datastore... not sure if the structure has changed recently or not... any thoughts/guidance there would be appreciated.
I honestly would not know. I'm inclined to just drop WFSV back in
community land, what do you think?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
