As many of you know a few of us attended a code sprint in Vienna last week, and decided to tackle GSIP 80.
http://geoserver.org/display/GEOS/GSIP+80±+Testing+Overhaul
I wrote up the results on the blog.
http://blog.geoserver.org/2012/09/30/vienna-code-sprint/
We worked on a branch called “fasttest”:
https://github.com/geoserver/geoserver/tree/fasttest
I have since cleaned it up a bit, separating some fo the core changes needed, and the test changes:
https://github.com/jdeolive/geoserver/tree/fasttest_clean
So with that in case anyone has ay more items for discussion i would like to push this one to a vote.
Thanks!
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
+1 of course
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Mon, Oct 1, 2012 at 8:22 AM, Justin Deoliveira <jdeolive@anonymised.com > wrote:
Thanks!
-Justin
Justin Deoliveira
Got visibility?
Most devs has no idea what their production app looks like.
Find out how fast your code is with AppDynamics Lite.
http://ad.doubleclick.net/clk;262219671;13503038;y ?
http://info.appdynamics.com/FreeJavaPerformanceDownload.html
Geoserver-devel mailing list
Hi, I am not a member of the PSC but I would vote +1
2012/10/1 Alessio Fabiani <alessio.fabiani@anonymised.com68… >
+1 of course
@alfa7691
Thanks!
-Justin
Justin Deoliveira
Got visibility?
Got visibility?
+1
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
+1
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
fax: +39 0584 962313
mob: +39 333 8128928
On Mon, Oct 1, 2012 at 11:05 AM, Andrea Aime
<andrea.aime@anonymised.com> wrote:
+39 0584 1660272
I have an additional idea how to speed up test times. Until now , for each setup a security migration is done. (Generating xml files, generating keys and a keystore, doing encryption,…).
If we could decide to use password digesting (not revertible) starting with fresh installations of Geoserver 2.3, we can save a lot of time bypassing migration code. For upgrading of existing installation , we can keep password encryption giving the admin the chance to revert to plain text passwords if needed.
Opinions ?
2012/10/1 Simone Giannecchini <simone.giannecchini@anonymised.com >
+1
Simone Giannecchini
@simogeo
Founder/Director
<andrea.aime@anonymised.com > wrote:
+39 0584 1660272
Got visibility?
Hey Christian,
Actually the new system tests actually prevent the migration from occuring by copying out a precanned 2.2.x security configuration into the data directory. Perhaps there are more savings to be gained though, any thoughts are welcome.
-Justin
On Mon, Oct 1, 2012 at 11:37 AM, Christian Mueller <mcrmcr21@anonymised.com > wrote:
Opinions ?
+1
Simone Giannecchini
@simogeo
Founder/Director
+39 0584 1660272
Got visibility?
Got visibility?
Justin Deoliveira
excellent, +1
On Mon, Oct 1, 2012 at 5:22 AM, Alessio Fabiani
<alessio.fabiani@anonymised.com> wrote:
+1 of course
@alfa7691
On Mon, Oct 1, 2012 at 8:22 AM, Justin Deoliveira <jdeolive@anonymised.com>
wrote:
http://geoserver.org/display/GEOS/GSIP+80+-+Testing+Overhaul
We worked on a branch called "fasttest":
Thanks!
-Justin
Justin Deoliveira
Got visibility?
Got visibility?
Gabriel Roldan
Awesome work guys, definitely +1 here.
One small thing - it’d be good to update the proposal to reflect that junit4 was chosen. It now reads a bit too speculative, and it’d be good to have the full decision trial made in it, like a bit of why junit4 was chosen (sounds like the two were super comparable, so it could even be ‘we flipped a coin’, but I imagine there was a slight bit more intent than that).
On Mon, Oct 1, 2012 at 11:48 AM, Gabriel Roldan <groldan@anonymised.com > wrote:
excellent, +1
<alessio.fabiani@anonymised.com > wrote:
+1 of course
@alfa7691
wrote:
Thanks!
-Justin
Justin Deoliveira
Got visibility?
Got visibility?
Gabriel Roldan
Got visibility?
+1 looks good
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
jive
October 1, 2012, 10:18pm
11
+1
Jody Garnett
On Monday, 1 October 2012 at 4:22 PM, Justin Deoliveira wrote:
Thanks!
-Justin
Justin Deoliveira
Got visibility?
http://ad.doubleclick.net/clk;262219671;13503038;y?
+1.
That looks great, Justin. I support the choice of JUnit 4 because I know it and not TestNG.
Thanks to everyone for their great effort in Vienna!
On 01/10/12 14:22, Justin Deoliveira wrote:
Thanks!
-Justin
Justin Deoliveira
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Christian, you are still on the PSC list (and the PSC as far as I know):
http://docs.geoserver.org/latest/en/developer/policies/psc.html
I do not recall you stepping down, nor the committee declaring your position vacant. Did I miss something in the minutes?
Software Engineer
And when you update the wiki with the results of the vote, please update the PSC list on the GSIP template.
Software Engineer
I think I am not allowed to edit
http://geoserver.org/pages/templates/viewpagetemplate.action?pageTemplateId=1114114&key=GEOS
2012/10/2 Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com >
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Don’t let slow site performance ruin your business. Deploy New Relic APM
Deploy New Relic app performance management and know exactly
what is happening inside your Ruby, Python, PHP, Java, and .NET app
Try New Relic at no cost today and get our sweet Data Nerd shirt too!
http://p.sf.net/sfu/newrelic-dev2dev
On Mon, Oct 1, 2012 at 9:52 AM, Chris Holmes <cholmes@anonymised.com > wrote:
Right. Will do. To sum up though it actually turned out that JUnit4 had some of the features that made testng look really attractive, namely test groups. That coupled with the fact that the juni4 upgrade was a little less invasive (no new eclipse plugins, etc… needed) and that geotools is already using Junit4 it made most sense imo.
excellent, +1
+1 of course
@alfa7691
wrote:
Thanks!
-Justin
Justin Deoliveira
Got visibility?
Got visibility?
Gabriel Roldan
Got visibility?
Got visibility?
Justin Deoliveira
this is a call for vote for the GSIP 79:
http://geoserver.org/pages/viewpage.action?pageId=49938445
This is the main thread discussion:
http://osgeo-org.1560.n6.nabble.com/GSIP-79-Json-support-and-WFS-and-WMS-ExceptionHandler-s-td4999973i20.html#a5003213
This is the pull request implementing requested changes for the master branch:
https://github.com/geoserver/geoserver/pull/41/
You are kindly invited to vote.
Carlo Cancellieri
+1
@alfa7691
On Wed, Nov 7, 2012 at 11:13 AM, Carlo Cancellieri <ccancellieri@anonymised.com > wrote:
Carlo Cancellieri
LogMeIn Central: Instant, anywhere, Remote PC access and management.
Stay in control, update software, and manage PCs from one command center
Diagnose problems and improve visibility into emerging IT issues
Automate, monitor and manage. Do more in less time with Central
http://p.sf.net/sfu/logmein12331_d2d
<ccancellieri@anonymised.com> wrote:
I already voted in the other thread with a +1
Ing. Andrea Aime
@geowolf
Technical Lead
+0
Simone Giannecchini
@simogeo
Founder/Director
On Wed, Nov 7, 2012 at 11:15 AM, Alessio Fabiani
+1
@alfa7691
branch:
Carlo Cancellieri
