Here is my rest version proposal:
http://geoserver.org/pages/viewpage.action?pageId=55574531
Feel free to post comments and remember to vote
Best regards,
Carlo Cancellieri - GeoSolutions SAS
Best regards,
The configuration file seems a bit odd to me:
resourceNameRegex=.+/(.*).(jar|war)
resourceAttributeExclusions=Import-Package,Export-Package,Class-Path,Require-Bundle
versionAttributeInclusions=Project-Version:Version,Build-Timestamp,Git-Revision,Specification-Version:Version,Implementation-Version:Git-Revision
Why have a blacklist instead of a whitelist for filtering the published properties? (Actually, why do the properties need to be filtered at all?)
Why provide for rewriting version attribute names? (and what happens if multiple attributes end up with the same name after rewriting?)
David Winslow
OpenGeo - http://opengeo.org/
On Tue, Dec 11, 2012 at 2:12 PM, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
http://geoserver.org/pages/viewpage.action?pageId=55574531Feel free to post comments and remember to vote
Best regards,
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Geoserver-devel mailing list
David,
I’m using it to avoid hardcoding of constants. If you think it is dangerous to expose it we can easily remove the datadir lookup.
Note that this configuration should be considered a plus, in most cases this file may not be created at all.
group(1) defines the name attribute of of the resource
list of properties to exclude from the resource
This is intentionally done. I only want to be able to exclude some too verbose parameters leaving the resource properties list open. So users can add their jars (with custom properties) having the complete list of properties. The configuration is exposed to be able to be more verbose (removing exclusions at all).
list of properties to include into the Version.
[optionally] You can specify a replacement string for a property key:
key:replace
The model uses a map to store attributes so the last attribute found into the manifest file will be used.
This is quite safe in my opinion since we are only using it in ‘versions’ (which exposes few and well known manifests files).
I added this capability (rename) to align the output of the ‘versions’ request, due to differences in Manifest.mf files between:
As you can see we have Implementation-Version in GeoWebCache and Git-Revision in GeoServer/GeoTools which should be exposed using the same name.
The same happens for Specification-Version (GWC) and Project-Version (GT/GS).
I appreciate your reply.
Carlo
David Winslow
Best regards,
On Tue, Dec 11, 2012 at 8:12 PM, Carlo Cancellieri <ccancellieri@anonymised.com…> wrote:
Looking good in general, some feedback:
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ok, makes sense. If the property filtering was somehow a security concern I’d have pushed for using a blacklist, but I guess we’re not too worried about that since administrators must explicitly enable access to the service by non-administrative users.
On Thu, Dec 13, 2012 at 4:15 AM, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
David,
Note that this configuration should be considered a plus, in most cases this file may not be created at all.group(1) defines the name attribute of of the resource
key:replace
This is quite safe in my opinion since we are only using it in ‘versions’ (which exposes few and well known manifests files).I added this capability (rename) to align the output of the ‘versions’ request, due to differences in Manifest.mf files between:
- GeoTools/GeoServer:
Manifest-Version: 1.0
Archiver-Version: Plexus Archiver
Created-By: Apache Maven
Built-By: jetty
Build-Jdk: 1.6.0_21
Build-Timestamp: 04-Dec-2012 02:31
Git-Revision: 380a2b8545ee9221f1f2d38a4f10ef77a23bccae
Project-Version: 9-SNAPSHOT
Class-Path: gt-opengis-9-SNAPSHOT.jar jsr-275-1.0-beta-2.jar vecmath-1
.3.2.jar commons-pool-1.5.4.jar jai_core-1.1.3.jar
- GeoWebCache:
Built-By: jetty
Build-Jdk: 1.6.0_21
Implementation-Title: org.geowebcache
Implementation-Vendor: http://geowebcache.org
Implementation-Version: 2a534f91f6b99e5120a9eaa5db62df771dd01688/2a534
Specification-Title: org.geowebcache
Specification-Vendor: http://geowebcache.org
Specification-Version: 1.3-SNAPSHOTAs you can see we have Implementation-Version in GeoWebCache and Git-Revision in GeoServer/GeoTools which should be exposed using the same name.
The same happens for Specification-Version (GWC) and Project-Version (GT/GS).I appreciate your reply.
Carlo–
David Winslow
OpenGeo - http://opengeo.org/On Tue, Dec 11, 2012 at 2:12 PM, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
Best regards,
Andrea,
thank you for feedback.
- following up the usual GeoServer REST conventions, in
/rest/about/resources.format the format should be optional and the default
should be HTML (the proposal does not say which formats are supported btw)
Added HTML support and modified proposal here:
http://geoserver.org/pages/viewpage.action?pageId=55574531#GSIP83-RESTExtensibleandcustomizableversionsreport%E2%80%8F-Supportedformats%3A
here is the pull request:
https://github.com/geoserver/geoserver/pull/85
Still missing documentation, I’m waiting for your votes.
To: andrea.aime@anonymised.com
Date: Wed, 19 Dec 2012 09:50:06 +0000
CC: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] GSIP 83 - REST Extensible and customizable versions report
Andrea,
------------------------------------------------------------------------------ LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial Remotely access PCs and mobile devices and provide instant support Improve your efficiency, and focus on delivering more value-add services Discover what IT Professionals Know. Rescue delivers http://p.sf.net/sfu/logmein_12329d2d
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
I should alreay voted for this gsip, however just in case … +1
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
mob: +39 331 6233686
On Thu, Dec 20, 2012 at 3:15 PM, Carlo Cancellieri <ccancellieri@anonymised.com> wrote:
https://github.com/geoserver/geoserver/pull/85Still missing documentation, I’m waiting for your votes.
CC: geoserver-devel@anonymised.comrge.net
Subject: Re: [Geoserver-devel] GSIP 83 - REST Extensible and customizable versions reportAndrea,
should be HTML (the proposal does not say which formats are supported btw)Added HTML support and modified proposal here:
http://geoserver.org/pages/viewpage.action?pageId=55574531#GSIP83-RESTExtensibleandcustomizableversionsreport%E2%80%8F-Supportedformats%3ACarlo Cancellieri - GeoSolutions SAS
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information.GeoSolutions S.A.S.
fax: +39 0584 1660272http://www.geo-solutions.it
Looks good to me. If I were to add a couple of things.
Just suggestions, both non blocking.
On Thu, Dec 20, 2012 at 9:56 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information.Ing. Alessio Fabiani
@alfa7691
Founder/Technical LeadGeoSolutions S.A.S.
fax: +39 0584 1660272mob: +39 331 6233686
Justin Deoliveira
Justin,
no problem, once approved I’ll add documentation and requested fixes.
Other suggestions? votes?
Date: Fri, 4 Jan 2013 11:42:31 -0700
To: alessio.fabiani@anonymised.com68…
CC: ccancellieri@anonymised.com; geoserver-devel@lists.sourceforge.net; andrea.aime@anonymised.com
@alfa7691
_______________________________________________ Geoserver-devel mailing list Geoserver-devel@anonymised.comsts.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Justin Deoliveira
Ciao Carlo,
I believe my vote is still missing.
Here you go: +0
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Tue, Jan 8, 2013 at 5:30 PM, Carlo Cancellieri
Justin,
no problem, once approved I'll add documentation and requested fixes.
Carlo Cancellieri - GeoSolutions SAS________________________________
versions report
andrea.aime@anonymised.comLooks good to me. If I were to add a couple of things.
* rename endpoint /about/resources to /about/manifest, seems a bit more
explicit about what it is returning
* rename "ManifestLoader.properties" to just "manifest.properties". More
inline with existing naming conventions and since its a user visible file
(ie. it lives in the data directory) it would be nice if it were in a more
"readable" format, rather than in Java camel case style.Just suggestions, both non blocking.
<alessio.fabiani@anonymised.com> wrote:I should alreay voted for this gsip, however just in case ... +1
@alfa7691
mob: +39 331 6233686http://www.geo-solutions.it
http://twitter.com/geosolutions_it-------------------------------------------------------
<ccancellieri@anonymised.com> wrote:Hi all,
https://github.com/geoserver/geoserver/pull/85Still missing documentation, I'm waiting for your votes.
thank you for feedback.- following up the usual GeoServer REST conventions, in
default
http://geoserver.org/pages/viewpage.action?pageId=55574531#GSIP83-RESTExtensibleandcustomizableversionsreport-Supportedformats%3ACarlo Cancellieri - GeoSolutions SAS
https://lists.sourceforge.net/lists/listinfo/geoserver-devel------------------------------------------------------------------------------
Justin Deoliveira
Enterprise support for open source geospatial.------------------------------------------------------------------------------
Master SQL Server Development, Administration, T-SQL, SSAS, SSIS, SSRS
and more. Get SQL Server skills now (including 2012) with LearnDevNow -
200+ hours of step-by-step video tutorials by Microsoft MVPs and experts.
SALE $99.99 this month only - learn more at:
http://p.sf.net/sfu/learnmore_122512
On Wed, Dec 19, 2012 at 10:50 AM, Carlo Cancellieri <ccancellieri@anonymised.com1…> wrote:
Andrea,
Cool thanks, +1
Ing. Andrea Aime
@geowolf
Technical Lead
I’ve just aligned and pushed last required changes.
The pull requests are missing the documentation which is currently under development (it will be produced using the proposal).
Could you kindly vote for this pull request?
Note that this can be easily backported to the 2.2.x so please vote also for the backport.
https://github.com/geoserver/geoserver/pull/105
Carlo
To: jdeolive@anonymised.com; geoserver-devel@lists.sourceforge.net
Date: Tue, 8 Jan 2013 16:30:58 +0000
Justin,
CC: ccancellieri@anonymised.com; geoserver-devel@anonymised.com.net; andrea.aime@anonymised.com
@alfa7691
Justin Deoliveira
------------------------------------------------------------------------------ Master SQL Server Development, Administration, T-SQL, SSAS, SSIS, SSRS and more. Get SQL Server skills now (including 2012) with LearnDevNow - 200+ hours of step-by-step video tutorials by Microsoft MVPs and experts. SALE $99.99 this month only - learn more at: http://p.sf.net/sfu/learnmore_122512
+1
2013/1/16 Carlo Cancellieri <ccancellieri@anonymised.com>
http://geoserver.org/pages/viewpage.action?pageId=55574531The pull requests are missing the documentation which is currently under development (it will be produced using the proposal).
https://github.com/geoserver/geoserver/pull/85Note that this can be easily backported to the 2.2.x so please vote also for the backport.
https://github.com/geoserver/geoserver/pull/105Cheers,
Carlo
Subject: Re: [Geoserver-devel] GSIP 83 - REST Extensible and customizable versions reportJustin,
CC: ccancellieri@anonymised.com; geoserver-devel@lists.sourceforge.net; andrea.aime@anonymised.comLooks good to me. If I were to add a couple of things.
- rename endpoint /about/resources to /about/manifest, seems a bit more explicit about what it is returning
- rename “ManifestLoader.properties” to just “manifest.properties”. More inline with existing naming conventions and since its a user visible file (ie. it lives in the data directory) it would be nice if it were in a more “readable” format, rather than in Java camel case style.
@alfa7691
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Justin Deoliveira
Enterprise support for open source geospatial.------------------------------------------------------------------------------ Master SQL Server Development, Administration, T-SQL, SSAS, SSIS, SSRS and more. Get SQL Server skills now (including 2012) with LearnDevNow - 200+ hours of step-by-step video tutorials by Microsoft MVPs and experts. SALE $99.99 this month only - learn more at: http://p.sf.net/sfu/learnmore_122512
Master Java SE, Java EE, Eclipse, Spring, Hibernate, JavaScript, jQuery
and much more. Keep your Java skills current with LearnJavaNow -
200+ hours of step-by-step video tutorials by Java experts.
SALE $49.99 this month only – learn more at:
http://p.sf.net/sfu/learnmore_122612
Christian,
sorry, your vote is for both proposal and backport to 2.2.x?
Date: Wed, 16 Jan 2013 17:55:09 +0100
Subject: Re: [Geoserver-devel] GSIP 83 - Call for vote
To: ccancellieri@anonymised.com21…
CC: jdeolive@anonymised.com; geoserver-devel@lists.sourceforge.net
+1
2013/1/16 Carlo Cancellieri <ccancellieri@anonymised.com.21…>
Carlo
To: jdeolive@anonymised.com; geoserver-devel@anonymised.comists.sourceforge.net
CC: ccancellieri@anonymised.com; geoserver-devel@anonymised.com.sourceforge.net; andrea.aime@anonymised.comLooks good to me. If I were to add a couple of things.
On Thu, Dec 20, 2012 at 9:56 AM, Alessio Fabiani <alessio.fabiani@anonymised.com68…> wrote:
@alfa7691
Justin Deoliveira
On Wed, Jan 16, 2013 at 4:28 PM, Carlo Cancellieri <ccancellieri@anonymised.com…> wrote:
Pull requests for a successfully voted GSIP do not need another vote, but they
need a review from someone.
The seems to be enough votes for the GSIP:
I’ll try to have a look at the pull request ASAP
I believe it is premature to vote for a backport, the change needs to stay on trunk some time
before we can even talk about a backport (I’d say one month at least, don’t think there
is a hard rule on this)
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea,
I’ve just committed documentation too.
Thank you!
Carlo
Ing. Andrea Aime
@geowolf
Technical Lead
+1 for the proposal. I am not sure about the back port, is it necessary ?. My vote for the backport is 0.
Andrea,
Thank you!
Carlo–
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more information.Ing. Andrea Aime
@geowolf
mob: +39 339 8844549http://www.geo-solutions.it
+0
@simogeo
Founder/Director
I've just aligned and pushed last required changes.
development (it will be produced using the proposal).Could you kindly vote for this pull request?
the backport.
Carlo________________________________
versions report
@alfa7691
default
Justin Deoliveira
SALE $49.99 this month only -- learn more at:
+1 on the proposal and the backport. Nice work Carlo.
On Thu, Jan 17, 2013 at 3:58 AM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
+0
Simone Giannecchini==
more information.Ing. Simone Giannecchini
@simogeo
Founder/DirectorGeoSolutions S.A.S.
fax: +39 0584 1660272mob: +39 333 8128928
the backport.
Carlo
To: jdeolive@anonymised.com; geoserver-devel@anonymised.coms.sourceforge.net
versions report
To: alessio.fabiani@anonymised.com268…
explicit about what it is returning- rename “ManifestLoader.properties” to just “manifest.properties”. More
“readable” format, rather than in Java camel case style.Just suggestions, both non blocking.
<alessio.fabiani@anonymised.com268…> wrote:I should alreay voted for this gsip, however just in case … +1
@alfa7691
default
Justin Deoliveira
Justin Deoliveira
