On Mon, Aug 24, 2015 at 11:28 AM, Brad Hards <bradh@anonymised.com> wrote:
After some work on CITE, I'm unhappy with the effort required to do a local
test (since you have to set up the test data). So I was going to suggest
that
we modify the "normal" release build to include a working test environment
such that tests will pass against a routine build without needing to modify
the data directory.
Interesting idea... with some gotchas.
The first one is that the CITE tests cannot be run against shapefiles due
to their attribute naming and data types
limitations... thus, we would have to ship H2 data stores with the right
data for the WFS compliance tests, instead,
and as a result, bundle the H2 store as a core one.
I'm not against, but would like to hear other devs opinions.
Another one is that the CITE tests expect their given data set, and I'm not
sure what happens
if other layers are made available as well.
We could try to use separate workspaces and use workspace specific
services, but WFS 1.0
needs two separate workspaces, so at least that one would have to be run
against global services.
Then there are the WCS tests, which fail if there is more than one version
of WCS deployed,
one has to selectively pull jars out of WEB-INF... again, we could add a
new feature to selectively
enable/disable WCS versions, would be nice, but to run the different tests,
one would still have
to unckeck the other versions... I guess I'd rather fix the CITE tests
instead.
For CSW tests, there is a gotcha that we would need to run against the
"basic store" instead
of the internal catalog one, so again a classpath manipulation. We could
make this configurable
again, or try to work on a composite store that allows more than one
backend store to be
used (would be useful too).
And then there are the other new tests that we are hopefully going to add,
not sure what
their requisites are, believe for example that WCS 2.0 has its own set of
expected data.
Hum... cannot think of other issues off the top of my head, but the ones
above are more than
enough imho
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
