I saw several people are against Virtual due to the misleading reference to GDAL integration (although Virtual as been originally inspired to the GDAL Virtual Raster capability to setup a Raster on top of other ones).
Let’s do a poll…
Please, let us know.
Best Regards,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Fri, May 23, 2014 at 2:02 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
Btw , thanks
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-devel mailing list
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
mob: +39 331 6233686
On Fri, May 23, 2014 at 2:01 PM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
No warries, I just did not find some time to read the proposal before today.
@alfa7691
On Fri, May 23, 2014 at 1:49 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Just rebooted confluence but I don’t imagine that will last for long.
On Fri, May 23, 2014 at 3:41 AM, Alessio Fabiani <alessio.fabiani@anonymised.com> wrote:
I cannot access to the proposal right now … for the moment I also would prefer another name.
Waiting for the possibility to read the proposal details before voting…
Justin Deoliveira
Vice President, Engineering | Boundless
@j_deolive
@alfa7691
On Wed, May 21, 2014 at 1:34 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
about the name, we initially thought about “Virtual Coverage” since we got inspired by GDAL “Virtual Raster”.
That’s not the very same thing, but with a “Virtual Raster” you may define a new Raster built on top of other Rasters, by defining some properties to customize how to use them.
So this is why we called that “Virtual Coverage”.
Well, when I saw the name “Virtual Coverage” I immediately thought “cool - it’s pulling data from that GDAL format, that might be useful”. But this apparently isn’t that. Others may have the same thought process, so I’m with those who suggest an alternate name; it’d help differentiate it. The “CompositeCoverage” suggestion is a good one.
Jonathan
