On Wed, Sep 2, 2015 at 8:45 PM, Gabriel Roldan <groldan@anonymised.com>
wrote:
What are you using it for?
To create the "style query" just like the renderer does, with a couple
modifications.
The best course of action would be to rely on RenderListener like for
GetFeatureInfo, just that we don't always need the resulting geometry to be
in "screen coordinates". It's format dependent, some require screen coords,
other target CRS coords. I'm guessing one could tweak the the request
arguments for the case where target CRS coords are required?
Err... not sure. You would have to disable geometry simplification (doable),
and then see if calling the paint method:
public void paint(Graphics2D graphics, Rectangle paintArea,
ReferencedEnvelope mapArea, AffineTransform worldToScreen) {
with a paintArea that is an integer version of the mapArea, and a
worldToScreen
that is the identy, gets you back the original geometries.
Tricky to make it work, and tricky to maintain imho
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
