GeoTools / GeoServer PMC meeting - 2021-01-05Attending
Actions from last meeting:
[DONE] Jody: Start email PSC vote this year to pay out of our 2020
budget for CITE test contract, and then send authorization to treasurer
when work is complete
[DONE] Jody: Will write it up as a proposal library/gt-http and
plugin/gt-http-components and send it to email for vote?
Alessandro: Make a PR against geoserver/docker to start this repository
going
Agenda
1.
OSGeo 2021 budget
2.
JTS 1.18 backport clarification
3.
JUnit 3 migration and PMD on tests
4.
gt-http proposal
5.
Java 11, Java 17, when do we drop Java 8?
Actions
OSGeo 2021 budget
Some great ideas from the last meeting, we did manage to pay GeoSolutions
with our 2020 budget. We did not get approval on the email list for 2020
budget…
Board requests a budget July 17th:
Draft: https://wiki.osgeo.org/wiki/GeoServer_Budget_2021
Sidebar:
How to rent a macOS build machine? AWS now provides an option …
An on-demand option could substantially mitigate costs, since we only
really need this 2 h every month or so (assuming we just want builds and
not ongoing integration tests)
A good discussion based on the recent JTS 1.18 update.
Want to be careful that we only backport additions that respect the API
Recent JTS 1.18 upgrade:
removed a couple of “internal” public classes (which would be fine…)
but also had a change where buffer(0) was required (so no backport…)
… this is a feature release (so no backport).
Internally:
Updating for bug fix / security issues can be backported no problem…
Security fix may need to force an api change (it happens)
New functionality that does not require api change backport after a month
Some care can be done for additive changes that do not break binary
compatibility
GeoTools should these guidelines also external dependencies? Since
downstream projects get these via transitive...
Action:
Torben: To write the above a bit more clearly in our developer guide
Sidebar:
Encouraging JTS to issue more patch releases
Have you seen the emails
Great hopes on automation, but failed when test extended another test …
Discovered PMD not running on test sources (required a flag), turning
that flag on destroyed happiness
Are these ready to merge?
They are boring to review …
Merge all three together
gt-http proposal
See proposal: https://github.com/geotools/geotools/wiki/HTTPClient-Factory
Please vote, want to get this in before code cut off?
Feedback:
CommonFactoryFinder? Or use an HTTPFactoryFinder (for standalone …).
Similar to logging this could be independent … Log4J upgrade anyone?
Going to be really tough to drop Java 8 Many projects have not made it
to Java 11 yet …
Java 8 supported longer than Java 11 according to AdoptJDK
Java 11
gt-http proposal wanted to use new java internal http client
Java 11 specific module?
Java 17 is due in 2021 September:
records, long strings, …
JTS Coordinate … we could lay the ground work in JTS 1.19 and then go
for an Unsafe / Java 17 combo
Expectation:
Expect we will end up moving to supporting LTS with Java 8 / Java 17 at
some point when Java 11 is dropped?
Java 8 / 11 / 17
Java 8 / 17
At some point ImageN - to get around com.sun image stuff
