[Geoserver-devel] GT/GWC/GS meeting minutes, October 15th 2019
GeoTools / GeoServer PMC meeting - 2019-10-15Attending
Andrea Aime
Jukka Rahkonen
Kevin Smith
Torben Barsballe
Actions from last meeting
   Torben: Update CITE compliance graphic on website
   Jody: CITE Proposals - Update amounts, and tally votes, … (Jody working
   on it)
   Jody: Reminder for GSIP-178, GSIP-176, GSIP-179, … (voted, passed)
Agenda
   1.
   PSC update
   2.
   Github committers cleanup
   3.
   CITE test updates
   4.
   Coveralls
   5.
   OSGeo election nominations
   6.
   Java 11 failing builds
Actions
   Clean up committers list on Github and SF (Andrea And Jody)
   Send mail to geoserver-devel asking committers to reply and confirm they
   are subscribed to users, devel and build list
PSC Update
Torben and Nuno proposed for PSC.
Both received votes from Andrea, Ian, Jukka, Kevin, Alessio, Simone. Motion
passed, welcome to the PSC.
Congrats!
   Action: Blog post welcoming new PSC members
   Action: Update the developers guide list, and templates
Jody has cleaned up Sourceforge already. Andrea to perform the first
cleanup on Github for committers.
   Action: cleanup github
   Action: Cleanup source forge developers list
   <https://sourceforge.net/p/geoserver/_members/&gt; to match github
CITE tests updates
Home page updated to report GeoServer is implementing. Closing
https://osgeo-org.atlassian.net/browse/GEOS-7089
   Website text updated, graphic still needed :slight_smile:
   Action: Jody to contact prior sponsors / interested parties?
      GeoSolutions, GeoCat, …
      Astun, OSGeo:UK, ATOL, Gaia3d, CCRi, FOSSGIS, IAG, Geodan, Vivid
      Solutions, GeoBeyond, San Jose Water Company, How2Map…
   Discussion:
      scripts to produce a server running geoserver that can be used to run
      cite tests against
Coveralls
Add code coverage to the PRs?
   Does it give a percentage?
   Maven plugin records prior values on a coveralls server, and compares to
   prior runs
   Should be a good point of discussion in reviewing the PR
   Tolerance is important, so failure with any negative number can prompt
   discussion
Action:
   Try it out, add to developers guide if we like it
OSGeo election nominations (charter members)
Nominations close on October 20th, is there any geoserver folks we should
nominate?
   Check against https://www.osgeo.org/about/charter-members/
      Ask first :slight_smile:
   PSC:
      Nuno? Already a charter member.
   Committers:
      Wait for github cleanup to have a shorter list?
Actions:
   Jody to review committers and look for any missed nominations
Email: Chatting with Fernando looks like he made some interesting
discoveries, I will let him follow up on this thread :slight_smile:
   False positive!
Back to java 11 failing because they forget their is a file system:
   Both surefire and maven stop seeing the file system?
   Is it out of disk space? Because we doubled up on the local maven repo …
   Cannot reproduce locally, seems specific to this AWS deployment
   NOUtils avoid cleanup on Java 11?
      aside: direct memory buffers issue is fixed after Java 9
Two JVMs running at the same time stop seeing the filesystem at the same
time.
   Jenkins also has a JVM monitoring the instance and may be interrupting?
Experiments:
   Torben is trying a different release of Java 11.
   Try building once on main machine (avoid use of monitor)
Chit Chat
   Josh Fix working on ImageIO activities for (optimized COG cloud reader)
   Andrea working on full preseeding of XYZ file system for a layer for GWC
   Jody is blocked on ImageJ (asked to remove some codecs)
   Martin wanted to pass on JTS clip improvements (perhaps use for for
   mapbox tiles)
CITE tests updates
Home page updated to report GeoServer is implementing. Closing https://osgeo-org.atlassian.net/browse/GEOS-7089
  • Website text updated, graphic still needed :slight_smile:
  • Action: Jody to contact prior sponsors / interested parties?
  • Boundless (Planet Federal), GeoSolutions, GeoCat, Astun, OSGeo:UK, ATOL, Gaia3d, CCRi, FOSSGIS, IAG, Geodan, Vivid Solutions, GeoBeyond, San Jose Water Company, How2Map…
  • Discussion:
  • Scripts to produce a server running geoserver that can be used to run cite tests against
I have decided to send out twitter message here: https://twitter.com/jodygarnett/status/1184272695443124224
And then appeal to the organizations above directly in the twitter thread. I can also look at companies that have been using GeoServer tag. I figure this is more public then email, lthough I could not find twitter contacts for vivid solutions, how2map, …
So far OSGeo:UK has responded
The geoserver.org page (and prior blog post) both have an updated progress graphic, and a working PayPal button.
Thanks Jody!
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Gaia3D has responded with $1000 (will wait for invoice before updating graphic).
Jody Garnett
On Thu, 17 Oct 2019 at 01:14, Andrea Aime <andrea.aime@anonymised.com> wrote:
Thanks Jody!
On Wed, Oct 16, 2019 at 8:16 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
CITE tests updates
  • Discussion:
Awesome!
On Thu, Oct 17, 2019 at 12:13 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Thanks Jody!
CITE tests updates
  • Discussion:
Geoserver-devel mailing list
how much is it missing from the objective?
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
On Thu, Oct 17, 2019 at 6:13 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Thanks Jody!
CITE tests updates
Discussion:
And then appeal to the organizations above directly in the twitter thread. I can also look at companies that have been using GeoServer tag. I figure this is more public then email, lthough I could not find twitter contacts for vivid solutions, how2map, ...
We will see at the end of the month, a few folks have been reaching out directly to me after last week’s twitter campaign.
I hope to update the graphic at some point this week and would appreciate any assistance promoting on social media.
Jody Garnett
I have updated the graphic on the website and blog post. We have raised a bit less than $7431 towards $10000 goal (I made it $7500 for the graphic).
  • Gaia3D $1000
  • Donations $1431
The donation button has been collecting small donations from $1 to $100 along side the published sponsorship levels. Because of the way paypal works I cannot always recognize the organization or name associated with the PayPal records. It may be appropriate to reach out to these email address and ask if they would like public recognition (should this activity go ahead).
Jody Garnett
On Mon, 21 Oct 2019 at 09:41, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Mon, 21 Oct 2019 at 08:51, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Simone Giannecchini
@simogeo
Founder/Director
Jody Garnett
Thanks Jody!
CITE tests updates
Discussion:
Here is social media update: https://twitter.com/jodygarnett/status/1186723982172573696
Please promote this activity if you have an opportunity to do so
Jody Garnett
On Tue, 22 Oct 2019 at 11:54, Jody Garnett <jody.garnett@anonymised.com> wrote:
  • Gaia3D $1000
  • Donations $1431
Jody Garnett
Jody Garnett
Simone Giannecchini
@simogeo
Founder/Director
Jody Garnett
Thanks Jody!
CITE tests updates
Discussion:
