[Geoserver-devel] gt-property migration - UI Test Failures
After converting geoserver to use gt-property-ng, I am getting a couple of UI-related test failures that appear to have nothing to do with my changes. When I test on master, these tests run fine.
In gs-web-core NewDataPageTest.testClickLink(): NullPointerException:
60 Label label = (Label) findComponentByContent(tester.getLastRenderedPage(), “Properties”, Label.class);
61 // getPath() will start with 0: which indicates the page
62 tester.clickLink(label.getParent().getPath().substring(2));
The label returned on line 60 is null, throwing a NullPointerException on line 62. (It seems that the label is not found on the last rendered page)
In gs-kml KmlTest.testRelativeLinks():
junit.framework.ComparisonFailure: expected:<[2]> but was:<[1]>
at junit.framework.Assert.assertEquals(Assert.java:100)
at junit.framework.Assert.assertEquals(Assert.java:107)
at org.custommonkey.xmlunit.XMLAssert.assertXpathEvaluatesTo(XMLAssert.java:858)
at org.geoserver.kml.KMLTest.testRelativeLinks(KMLTest.java:391)
391 assertXpathEvaluatesTo(“2”, “count(//kml:Folder/kml:NetworkLink)”, dom);
It looks like two links are expected (A “next” and a “previous” )but only one is found. Looking at the dom, it seems that this is a “previous” link, suggesting that we are on the last page.
This issue at least seems like it might be related to the number of results returned (Which could in turn be related to the PropertyDataStore implementation), but it is a bit odd that similar problems haven’t shown up elswhere if this is the case.
Does anyone know anything that could cause a change in PropertyDataStore to affect the UI like this?
Torben Barsballe
On Tue, Dec 30, 2014 at 1:48 AM, Torben Barsballe <
findComponentByContent(tester.getLastRenderedPage(), "Properties",
Label.class);
Making a quick guess here, the labels in the new data page tests are based
on the store names returned by the factory, maybe it has changed in
property-ng?
    at
391 assertXpathEvaluatesTo("2", "count(//kml:Folder/kml:NetworkLink)",
dom);
It looks like two links are expected (A "next" and a "previous" )but only
one is found. Looking at the dom, it seems that this is a "previous" link,
implementation), but it is a bit odd that similar problems haven't shown up
I don't remember by heart, but yeah, it seems it is count-dependent. By the
way, this is not a UI tests, gs-kml it's the KML output format module
Please, notice that GeoSolutions will be closed for seasonal holidays
from December the 24th to January the 6th
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
