Hello,
I'm Paolo Marinelli. I checked out the source code of Geoserver 1.4.x, and I found that it makes use of some gt2-2.2.3-SNAPSHOT packages (e.g., gt2-render-2.2.3-SNAPSHOT.jar).
Where can I find the source code of 2.2.3-SNAPSHOT packages?
I tried out with the command
mvn eclipse:eclipse -DdownloadSources=true
but maven2 didn't download the source code for the 2.2.3-SNAPSHOT packages
I also looked for within the geotools repository
http://svn.geotools.org/geotools/tags
but I didn't find the 2.2.3-SNAPSHOT version.
Can you help me?
Many thanks!
Regards
Paolo
Passa a Infostrada. ADSL e Telefono senza limiti e senza canone Telecom
http://click.libero.it/infostrada16gen07
marinello80 ha scritto:
Hello,
Check out the 2.2.x branch, that's where 2.2.3-snapshot is.
2.2.x hosts the code for the 2.2.x series, each time a release
is cut, the version of all poms becomes 2.2.<nextVersion>-snapshot.
Last release from 2.2.x was 2.2.2, thus now the version is 2.2.3-snapshot.
Hi Paolo
You can checkout the geoserver source for 2.2.x using SVN at:
http://svn.geotools.org/geotools/branches/2.2.x
You can fine the renderer source under the directory:
/module/render/
For information on how to get and use the geotools source refer to this page:
http://docs.codehaus.org/display/GEOT/Home
good luck!
Brent Owens
(The Open Planning Project)
marinello80 wrote:
Hello,
Can you help me?
Many thanks!
Regards
Paolo
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-devel mailing list
