[Geoserver-devel] gt2-xmlcodegen missing in build
"svn up" gives the following error:
D configuration\release\featureTypes\alaska_alaska
U configuration\release\featureTypes\states\info.xml
U configuration\release\featureTypes\tasmania_water_bodies\info.xml
U configuration\release\featureTypes\tasmania_roads\info.xml
U
configuration\release\featureTypes\tasmania_state_boundaries\info.xml
U configuration\release\featureTypes\tasmania_cities\info.xml
U configuration\release\services.xml
U configuration\release\styles\tiger_roads.sld
A configuration\release\demo\WMS_getMap_inlineFeatureSmile.xml
U configuration\release\catalog.xml
A configuration\release\templates
A configuration\citewcs\templates
A configuration\citewfs-1.1\templates
U
configuration\community-schema\featureTypes\Borehole\BoreholeTest_proper
tie
s.xml
U configuration\community-schema\featureTypes\Borehole\info.xml
U configuration\community-schema\services.xml
U configuration\community-schema\catalog.xml
A configuration\community-schema\templates
D configuration\versioning\demo\01_WFSV_GetFeature.xml
D configuration\versioning\demo\05_WFSV_GetLogArchsites.xml
D configuration\versioning\demo\04_WFSV_GetFeatureLog.xml
D configuration\versioning\demo\03_WFSV_GetFeatureBeforeAfter.xml
D configuration\versioning\demo\02_WFSV_Transaction.xml
A configuration\versioning\demo\WFSV_01_GetFeature.xml
A configuration\versioning\demo\WFSV_05_GetLogArchsites.xml
A configuration\versioning\demo\WFSV_04_GetFeatureLog.xml
A configuration\versioning\demo\WFSV_07_GetReverseDiffArchsites.xml
A configuration\versioning\demo\WFSV_03_GetFeatureBeforeAfter.xml
A configuration\versioning\demo\WFSV_06_GetDiffArchsites.xml
A configuration\versioning\demo\WFSV_09_TransactionVersionAware.xml
A configuration\versioning\demo\WFSV_02_Transaction.xml
A configuration\versioning\demo\WFSV_08_TransactionRollback.xml
A configuration\versioning\templates
A configuration\citewfs\templates
A configuration\minimal\templates
A configuration\citewms\templates
Fetching external item into 'geoserver\web\minimal'
svn: PROPFIND request failed on '/geoserver/trunk/configuration/minimal'
svn: PROPFIND of '/geoserver/trunk/configuration/minimal': could not
connect to
server (http://svn.codehaus.org)
Jerry.
-----Original Message-----
From: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Sent: 16 March 2007 15:24
To: Swan Jerry
Cc: geoserver-devel@lists.sourceforge.net
Subject: Re: [Geoserver-devel] gt2-xmlcodegen missing in build
Hi Jerry,
Thanks!! You just spotted a problem with our build system that we never
caught before. I have fixed the problem so that you should be able to
build. Just do an "svn up" and then try again and it should work ok.
-Justin
Swan Jerry wrote:
I get the maven log below when attempting to build geoserver.
The seemingly relavent maven-metadata-central.xml file in the maven
repository is:
<?xml version="1.0" encoding="UTF-8"?><metadata>
  <groupId>org.geotools.maven</groupId>
  <artifactId>gt2-xmlcodegen</artifactId>
  <version>LATEST</version>
</metadata>
The closest match I can find by websearch is
gt2-xmlcodegen-2.4-SNAPSHOT.jar
Is this suitable?
Should I be attempting to manually install this file?
Is the absence of this file simply an artefact of some higher-level
problem?
Any advice greatly appreciated.
Jerry.
[INFO] Scanning for projects...
[INFO]
[INFO] Building Maven Default Project
[INFO] task-segment: [compile]
[INFO]
[INFO]
[ERROR] BUILD ERROR
[INFO]
-- [INFO] Cannot execute mojo: resources. It requires a project with
an existing po m.xml, but the build is not using one.
[INFO]
-- [INFO] For more information, run Maven with the -e switch [INFO]
[INFO] Total time: < 1 second
[INFO] Finished at: Fri Mar 16 11:24:09 GMT 2007 [INFO] Final Memory:
2M/4M [INFO]
C:\sw_dev\java\geoserver-1.5.0-rc2>cd trunk
C:\sw_dev\java\geoserver-1.5.0-rc2\trunk>mvn compile [INFO] Scanning
for projects...
[INFO]
[INFO]
[INFO]
[ERROR] BUILD ERROR
[INFO]
[INFO]
[INFO] Finished at: Fri Mar 16 11:24:17 GMT 2007 [INFO] Final Memory:
2M/4M [INFO]
C:\sw_dev\java\geoserver-1.5.0-rc2\trunk>dir
Volume in drive C has no label.
Volume Serial Number is 35DD-2A50
Directory of C:\sw_dev\java\geoserver-1.5.0-rc2\trunk
13/03/2007 11:44 <DIR> .
13/03/2007 11:44 <DIR> ..
14/03/2007 13:50 <DIR> configuration
14/03/2007 13:50 <DIR> geoserver
               0 File(s) 0 bytes
               4 Dir(s) 232,155,832,320 bytes free
C:\sw_dev\java\geoserver-1.5.0-rc2\trunk>cd geoserver
C:\sw_dev\java\geoserver-1.5.0-rc2\trunk\geoserver>mvn compile [INFO]
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Plugins configuration files
[INFO] Configuration Deployment PlugIn
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Model
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Web Feature Service Model
[INFO] Validation Module
[INFO] Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Test Module
[INFO]
[INFO] Building GeoServer
[INFO]
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT:
checking for
updates from codehaus-snapshot-plugins [INFO] snapshot
checking for
updates from refractions
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for
updates from co dehaus-snapshot-plugins [INFO] snapshot
org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from re
fractions [INFO] No goals needed for project - skipping [INFO]
[INFO] Building GeoServer Maven Plugins
[INFO]
[INFO] Building Plugins configuration files
[INFO]
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin:
checking for up
dates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin:
checking for upd ates from mortbay-repo [INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[WARNING]
        Artifact junit:junit:jar:3.8.1:test retains local scope 'test'
overridin
g broader scope 'compile'
        given by a dependency. If this is not intended, modify or
remove the loc al scope.
[INFO] snapshot org.geotools:gt2-api:2.4-SNAPSHOT: checking for
updates from ref ractions [INFO] snapshot
org.geotools:gt2-library:2.4-SNAPSHOT: checking for updates from
refractions [INFO] snapshot org.geotools:gt2-modules:2.4-SNAPSHOT:
checking for updates from refractions [INFO] snapshot
org.geotools:gt2:2.4-SNAPSHOT: checking for updates from refract ions
[INFO] snapshot org.opengis:geoapi-nogenerics:2.1-SNAPSHOT: checking
org.opengis:parent:2.1-SNAPSHOT: checking for updates from refra
ctions [INFO] snapshot org.geotools:gt2-referencing:2.4-SNAPSHOT:
org.geotools:gt2-metadata:2.4-SNAPSHOT: checking for updates fro m
refractions [INFO] snapshot org.geotools:gt2-main:2.4-SNAPSHOT:
checking for updates from re fractions [INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date [INFO]
[INFO] Building Configuration Deployment PlugIn
[INFO]
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking
for updat es from mortbay-repo [WARNING]
        Artifact
org.apache.maven:maven-artifact-manager:jar:2.0:runtime
retains
local scope 'runtime' overriding broader scope 'compile'
[WARNING]
        Artifact
org.apache.maven:maven-plugin-tools-api:jar:2.0.5:runtime retai ns
[WARNING]
        Artifact org.apache.maven:maven-plugin-api:jar:2.0:runtime
retains local
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java [INFO] Extractor for
language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh [INFO] Extractor for
language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant [INFO] Extractor for
language: ant found 2 mojo descriptors.
[INFO] No sources to compile
[INFO]
[INFO] Building Core Platform Module
[INFO]
[INFO] Building Data Module
[INFO]
[INFO] Building Open Web Service Model
[INFO]
Downloading:
http://www.ibiblio.org/maven2/org/eclipse/emf/common/2.2.1/common-2
.2.1.pom
[WARNING] Unable to get resource from repository ibiblio
(http://www.ibiblio.org
/maven2)
Downloading:
http://maven.geotools.fr/repository//org.eclipse.emf/poms/common-2.
2.1.pom
[WARNING] Unable to get resource from repository geotools
(http://maven.geotools
.fr/repository/)
Downloading:
http://lists.refractions.net/m2//org/eclipse/emf/common/2.2.1/commo
n-2.2.1.pom
[WARNING] Unable to get resource from repository refractions
(http://lists.refra
ctions.net/m2/)
Downloading:
http://maven.espace.ird.nc/org/eclipse/emf/common/2.2.1/common-2.2.
1.pom
[WARNING] Unable to get resource from repository espace
(http://maven.espace.ird
.nc)
Downloading:
http://www.mortbay.org/maven2/release/org/eclipse/emf/common/2.2.1/
common-2.2.1.pom
[WARNING] Unable to get resource from repository mortbay
(http://www.mortbay.org
/maven2/release)
Downloading:
http://repo1.maven.org/maven2/org/eclipse/emf/common/2.2.1/common-2
.2.1.pom
[WARNING] Unable to get resource from repository central
(http://repo1.maven.org
/maven2)
[INFO] Building Open Web Service Module
[INFO]
[INFO]
[ERROR] BUILD ERROR
[INFO]
-- [INFO] The plugin 'org.geotools.maven:gt2-xmlcodegen' does not
exist or no valid version could be found [INFO]
[INFO] Total time: 24 seconds
[INFO] Finished at: Fri Mar 16 11:24:50 GMT 2007 [INFO] Final Memory:
10M/20M [INFO]
This message has been checked for viruses but the contents of an
attachment may still contain software viruses, which could damage your
computer system:
you are advised to perform your own checks. Email communications with
the University of Nottingham may be monitored as permitted by UK
legislation.
--- Take Surveys. Earn Cash. Influence the Future of IT Join
SourceForge.net's Techsay panel and you'll get the chance to share
your opinions on IT & business topics through brief surveys-and earn
cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEV
DEV _______________________________________________
Geoserver-devel mailing list
!DSPAM:4007,45fa8233224752081064789!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
connect to
This path is there and working now. You probably just had a temporary connection issue with the server, I suggest to retry the update.
