[Geoserver-devel] gt2-xmlcodegen missing in build
Swan Jerry ha scritto:
http://svn.codehaus.org/geoserver/trunk/configuration/minimal/ with a
browser work for you?
Yes.
Did you check out only
http://svn.codehaus.org/geoserver/trunk/geoserver
or the whole http://svn.codehaus.org/geoserver/trunk?
The latter.
Fishy, there must be something broken in the checkout then...
What version of svn are you using? I'm on 1.4.3
As a last tentative, I would wipe out the web directory, then
do a svn up again.
