[Geoserver-devel] gt2WMS moving to GeoServer project
Apologies for the large cross-post, please direct replies to
geoserver-devel@anonymised.com
The gt2wms server is moving to the GeoServer project. We've been wanting
to move the wms server out of GeoTools for awhile, as it doesn't really
fit with the rest of the modular nature. Over at GeoServer we were
planning on integrating the gt2wms anyways, so it seems to make sense to
have the code actually live on in the same cvs. This way our developers
can benefit from one another's approaches, and hopefully combine common
code. Both are OGC web services on top of Geotools, so there should be a
few places of overlap. I'm planning on spending the rest of this week on
integration, and initial attempts are promising. I've successfully got
them running in the same war, and can recieve a getCapabilities document
for both.
There are a few questions that I have, for all interested in the future of
gt2wms, and its integration into geoserver.
1. How much integration do we want? I think common configuration would be
nice to have, so that both services could use the same configuration
files. GetCapabilities responses and Exception handling also seem like
they have some overlap, so we might try to combine those classes. We can
talk more specifics on the geoserver devel list.
2. Maven on GeoServer? The GeoServer project currently uses ant, which is
nice and fast, and currently easier to get working (though maven 1.0 may
prove that wrong). Getting GeoServer on Maven would allow us to more
quickly pick up geotools changes - right now I hand roll the geotools jar
and put it on cvs, which is obviously less than ideal. My plan is to
start tagging geotools with geoserver tags of what is needed, but using
maven would make that less necessary, as it would just download the proper
jars. I'm a bit inclined to stay with ant, but if someone (James?) is
willing to set it up and no one's against the change I'll go along.
3. Package names for the gt2wms. Do we want to keep the geotools package
names, since that's where the code comes from? Or do we want to make a
org.vfny.geoserver.wms package? Or if we're going for a lot of
integration we could make org.vfny.geoserver.requests.wms and
org.vfny.geoserver.responses.wms, and put all the common config code in
org.vfny.geoserver.config. And we can obviously start with one and move
things around if and when we actually acheive integration.
4. Distribution and Marketing. These questions are not pressing, but how
do we want to present the wms? Should we make it available as a
stand-alone wms? Keep the downloadable war format? Integrate it
completely into GeoServer? Create seperate installation instructions?
Many of these questions depend on how much we integrate, but even if we do
integrate a lot we can still have them live as slightly different projects
in user's minds, just ones that inter-operate quite well.
Ok, I'm sure there will be more questions about this, but we can hold off
for discussion on geoserver-devel.
  thanks,
       Chris
Just a very simple consideration:
----- Original Message -----
To: <geotools-devel@lists.sourceforge.net>;
<geotools-gt2-users@lists.sourceforge.net>;
<geoserver-devel@lists.sourceforge.net>
Sent: Tuesday, September 30, 2003 9:06 PM
Subject: [Geotools-devel] gt2WMS moving to GeoServer project
IMHO, wich is only derived from my experiences in developing server side
GIS apps for last 3 years, in all of them there are situations where
definitely a pure
WMS or a pure WFS doesn't is enough. Instead, one must take each ohter
to solve a current problem. I mean, until now I was using ArcIMS,
extensively
working with its AXL format, to query images as to retrieve geometries,
working
on it, and applying bussines logic as a whole.
And since ArcIMS is not the best product I've seen, having a product that
can
manage both needs helps a lot. I would be a mess to use one product to
quering maps and another (or at least one not well integrated with the
datasets working on)
for working with features at a lower level.
That's why mi position is to get the greater integration level possible.
regards,
Gabriel
for both.
Great, having a frozen WMS in GeoTools and now having it warming up in
GeoServer is good news !
I have successfully (so far) installed and used both of them as separated web
apps. I think using or sharing same configuration context would be nice. The
geoserver configuration system is simple, straight and easy to follow !
As I am doing a cvs check out of GeoTools source once a week and compile it
with Maven, using Maven or ant is not the all story ! What would be cool is
the ease compilation of GeoServer with GeoTools jars just compiled on the
same machine!
GeoTools was using ant before switching to Maven, I strongly believe that
Maven helped a lot in having the whole GeoTools tree compiled.
Sounds a practical view : starting with gt2wms for the handing-over and ending
with org.vfny.geoserver.* when strong integration is reached.
Having two pieces of webapp (WMS and WFS) is good for webapp developers
willing not to care of both services at the same time. Integration should be
avaiblable at the configuration level (especially if you want to build maps
with WMS and using the same geo-data send GML with WFS). This may allow
strong interoperability between them. Somewhere the key point will be having
the common jar files (like geotools2) in one or more places.
  thanks,
       Chris
This sf.net email is sponsored by:ThinkGeek
Welcome to geek heaven.
http://thinkgeek.com/sf
Geotools-gt2-users mailing list
Geotools-gt2-users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
didier
I know the geoserver developers shold see the deegree project, they are a
strongly interoperability wms and wfs samples,
please visit this comunity, your wms application not connect to database
directly, the wms connect with an wfs server, that wfs is
connect directly to the database or shapefiles, etc. and the wms extract the
information from the wfs in gml format trouhgt wfs request.
William Moreno
The arquitecture of this samples application is one interesting model to
study for the integration gt2wms and geoserver
To: <geoserver-devel@lists.sourceforge.net>
Sent: Tuesday, September 30, 2003 4:12 PM
Subject: [Geoserver-devel] Re: [Geotools-gt2-users] gt2WMS moving to
GeoServer project
wanting
a
on
> for both.
of
be
can
web
The
is
jar
proper
it
is
same machine!
package
ending
how
do
projects
be
maps
having
off
> thanks,
> Chris
didier
Geoserver-devel mailing list
Yes, I do like their design a lot, I think it's quite smart. It might be
a good aim for the future. For now I've had success serving up the same
featureType as an image through the gt2wms code and as gml through wfs
code, on the same servlet. I'll try to get this into cvs soon. Both are
built on top of geotools, so integrating them to just work is actually
quite easily. There are opportunities for more overlap, like exception
reporting and whatnot, which deegree does.
Also we are slowly working to have an integrated feature model with
deegree. The first step is geometries, which have taken the form of the
GeoAPI project, which has been moving along more slowly than we'd all
like. But if and when we do get a common feature model then geoserver
should be able to serve as a wfs for the deegree wms, which would be quite
cool. The next step after that would be to have the gt2wms use the wfs as
a datasource in their style, and then some interfaces allowing us to
easily transfer data between the projects.
So yes, my thought is to have the wms connect to the databases directly
for now, as I've just about finished that, and work later for deegree
style interoperability.
  Chris
William Moreno
GeoServer project
wanting
a
on
> > for both.
of
be
can
web
The
is
jar
proper
it
is
> same machine!
package
ending
how
do
projects
be
maps
having
off
> > thanks,
> > Chris
> > _______________________________________________
> didier
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
I try to connect geoserver with deegree wms but i can't,
Can you help me?, you have experience in deegree?
William Moreno
To: "Bladimir Moreno" <bladiyo@anonymised.com>
Cc: "Richard didier" <dgr@anonymised.com>;
Sent: Thursday, October 02, 2003 11:22 AM
Subject: Re: [Geoserver-devel] Re: [Geotools-gt2-users] gt2WMS moving to
GeoServer project
Chris
a
the
> William Moreno
> From: "Richard didier" <dgr@anonymised.com>
> GeoServer project
> wanting
really
sense to
developers
common
be
> a
week
> on
got
document
> > > for both.
future
> of
would
> be
like
We
> can
separated
> web
nice.
> The
which
> is
may
more
geotools
> jar
to
using
> proper
is
compile
> it
cool
> is
the
> > same machine!
that
> package
make a
in
move
and
> ending
but
> how
instructions?
we
> do
> projects
developers
should
> be
> maps
allow
> having
hold
> off
> > > thanks,
> > > Chris
> > didier
I would have serious reservations about moving to a WFS only datasource for the WMS server. Supporting WFS for those datasources that Geotools does not support natively is a good idea, but using WFS as an another layer between the WMS and the actual data, when Geotools supports the data sources natively is a bad idea imo. It is just asking for performance issues. There is no advantage of adding the extra layer of parsing and encoding when the same functionality can be acheived through the Geotools DataSource API. Sure it is a nice demostration of chaining services but the performance hit would be too much imo.
Sean
Chris
I agree, we don't want only WFS datasource. Just as another option.
Basically I think it'd be nice to accept deegree wfs as a geotools
datasource, and have deegree wms accept geoserver as a datasource. For
the former we would just interface with their wfs, which can send features
instead of gml, if and when our feature models are harmonized. For the
latter we need to be serve up serialized harmonized features. Sorry for
the confusion, I didn't mean to imply that we'd get rid of geotools
datasources, just that we'd seek more options for interoperability. I can
easily see how what I wrote could be read that way.
  Chris
Sean
> Chris
Could we say that, viewed from WMS, any WFS can be seen as a datasource :
GeoTools DataSource API needs {get|add|remove|modify|set}Features(),
commit(), rollback(), setAutoCommit(), getAutoCommit(),
{get|create}MetaData(), getSchema(), abortLoading(), getBounds() methods ...
I believe that a WFS can been seen through its operations as another gt2
datasource.
Having such a WFS datasource (and testing it with deegree) allow access to any
GIS component that has a WFS not only flat files (like Shapefile) or DBMS
(like postgreSQL), but (hopefully ?-) with ArcIMS, GeoMedia, etc. Which leads
us to "real" (or better) interoperability.
didier
  Chris
> Sean
> >> extract the information from the wfs in gml format trouhgt wfs
> >> request.
> > Chris
