Hi lists,
sorry for cross-posting.
I have noticed that the GS-2.15 build keeps failing since 2 days.
After some investigation I have noticed that, for some reason, it is still inheriting an old dependency and I think that I figured out why:
The GWC 1.15.x pom is actually declaring 1.15.1 version instead of 1.15-SNAPSHOT.
I have created a PR to restore the -SNAPSHOT on GWC poms.
https://github.com/GeoWebCache/geowebcache/pull/753
Just reporting that in case you may want to check if there is any issue with a GWC release script (or maybe it was just an oversight during release, not a big deal in that case)
Daniele
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
