[Geoserver-devel] GWC 1.5.2 patch release imminent
Hi all, due to a bug[1] in GWC 1.5.0/1.5.1 that prevents truncate tasks from finishing/running at all when a tile layer has cached tiles for more than one gridset, I’m about to create the 1.5.2 patch release.
GeoServer 2.5.x got the fix right away as it depends on GWC 1.5-SNAPSHOT.
But I would need to up the gwc dependency on GeoServer 2.4.x from 1.5.0 to 1.5.2.
I have made an amendment on an incompatible API change between gwc 1.5.0 and 1.5.1 [2], which should have not been introduced (being a patch version), so there’s absolutely no change to make in the geoserver code base.
So just checking it’d be ok to upgrade gs 2.4.x to gwc 1.5.2 once released later today?
TIA,
Gabriel
[1] <https://github.com/GeoWebCache/geowebcache/commit/419cf990efe3da3f736a5011424d87585551bb08>
[2] <https://github.com/GeoWebCache/geowebcache/commit/17b26efda4ab2d310ba7aa0597ff2db41626f761>
Gabriel Roldán
Software Developer | Boundless
groldan@anonymised.com
@gabrielroldan
+1 here.
TIA,
Gabriel
Gabriel Roldán
@gabrielroldan
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos. Get
unparalleled scalability from the best Selenium testing platform available.
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geowebcache-devel mailing list
Geowebcache-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geowebcache-devel
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
Hello,
GWC 1.5.2 is out. Here’s a PR to update GS 2.4.x <https://github.com/geoserver/geoserver/pull/580>
Please review and consider merging. It fixes a legit bug by which truncate tasks can’t be run.
TIA,
Gabriel
On Fri, May 2, 2014 at 4:29 PM, Kevin Smith <ksmith@anonymised.com> wrote:
+1 here.
Gabriel Roldán
@gabrielroldan
TIA,
Gabriel
Gabriel Roldán
@gabrielroldan
Kevin Smith
+1-778-785-7459
@boundlessgeo
