[Geoserver-devel] GWC and Spring 3.0.5
At the moment I try to migrate geoserver trunk to Spring 3.0.5 and Spring Security 3.0.5. Until now, the Spring migration is the easy part, Spring Security is much harder.
A mvn clean install runs all tests except some gwc tests.
Looking at
https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/pom.xml
I see that gwc uses Spring 2.5.5. How to continue ?
Christian
This message was sent using IMP, the Internet Messaging Program.
Looking at
Uh, that might be problematic, GWC should also do the switch to 3.0.5 I guess?
But it's up to the GWC developers to decide whether they want to switch, in what
time (afaik there are other modifications going) and who can look into it.
If I remember properly GWC makes a relatively lightweight usage of Spring, so
it may be that migrating it it's not that hard? Proposing a patch to switch GWC
to Spring 3.0.5 might be a good step forward (though, let's hear from Gabriel
about this).
Christian
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Hi Christian,
migrating gwc to Spring 3 sounds good to me. If you feel like providing
a patch that'd be great, cause I'm not sure when I'll be able to do that
myself. For sure not before next week, though next week I think I could.
We use github:https://github.com/GeoWebCache/geowebcache
Or, to make things easier, you just need to migrate the context files in
the geoserver's gwc module, under src/main/resources, as gwc doesn't
come with them embedded in the jars (except for the gwc web module that
we don't depend on)
Gabriel
> Looking at
about this).
> Cheers
> Christian
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
Solved, I had to modify
src/main/resources/geowebcache-geoserver-context.xml
and changed
<bean id="gwcFacade" class="org.geoserver.gwc.GWC">
to
<bean id="gwcFacade" class="org.geoserver.gwc.GWC" depends-on="gwowebCacheExtensions">
Now all tests pass.
At the moment I have an successful
mvn clean install -P allExtensions.
I will make some additional tests, open a JIRA issue and attach a patch.
Christian
Quoting Gabriel Roldán <groldan@anonymised.com>:
Hi Christian,
we don't depend on)
Gabriel
> Looking at
about this).
> Cheers
> Christian
Gabriel Roldan
