as you probably know it’s currently impossible to use workspace specific
styles with GWC, any attempt to use them just fails with exception.
Which basically means, GWC does not work at all in a multitenancy setup.
There is this “workspace” extra param that can be used, but it is not a good solution,
people need to know it has to be added, it’s not transparent as the integrated
GWC strives to be.
After talking with the n-th user that would have liked to use virtual services, but
was blocked by this issue, I got a little frustrated and asked myself “how hard
can it be?”.
After a couple of hours of hacking, the answer seems to be “not much”.
I’ve leveraged the support for prefixed style names in the catalog and
modified a bit the integration, so that everywhere a style name was used,
a prefixed name is now used instead.
I’ve then modified the tests for the “workspace” param to just remove it,
updated the many mock tests we have to use prefixedName, and voilà,
it seems to be working ok, it can be seeded and truncated,
and used in the GWC preview.
I’ve then checked the direct integration, which at first was not fully working
because the WMSWorkspaceQualifier was not qualifying styles too (a bit
trickier than qualifying layers, as a style can be both local and global).
After changing this also direct integration seems to be working ok, whether
a style is not specified, specified without or with prefix.
Anyways… would be nice if someone else could check this pull request?
https://github.com/geoserver/geoserver/pull/908
Going to have a look also at http://jira.codehaus.org/browse/GEOS-6512,
it was reported against the opengeo suite (sigh!), but I guess it can be reproduced
also with a standard geoserver.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
