[Geoserver-devel] GWC Dev
Hi All,
If I were to implement logic, so that GWC re-seeded a layer only for tiles which are within list of polygons which is defined in a geoRSS file, where would I start for implementing that logic?
Many thanks,
Steve
I think what you want may already be implemented?
http://geowebcache.org/docs/current/configuration/layers/georss.html
It could use more examples of making the GeoRSS feed perhaps. Have you tried it? Or is there more functionality you’re imagining? I think maybe reseeding doesn’t work super well?
On Fri, Jun 24, 2011 at 10:37 AM, Steve Way <Steve.Way@anonymised.com> wrote:
Hi All,
Many thanks,
Steve
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech or Mail.Admin@anonymised.com and delete the original message.
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense…
http://p.sf.net/sfu/splunk-d2d-c1
Geoserver-devel mailing list
To add to what Chris said, just beware this is the format for the feed
GWC understands:
<https://github.com/GeoWebCache/geowebcache/blob/master/geowebcache/georss/src/test/resources/org/geowebcache/georss/test-data/mixedgeometries_feed.xml&gt;
You'll need to code it, and upon geometry updates, make sure to
include an entry for the old geometry and another one for the new one,
so that gwc truncates based on the whole change.
In the future GeoServer will have a GeoSynchronization Service and
hope a GWC client comes along.
cheers,
Gabriel
On Fri, Jun 24, 2011 at 1:51 PM, Chris Holmes <cholmes@anonymised.com> wrote:
tried it? Or is there more functionality you're imagining? I think maybe
reseeding doesn't work super well?
Hi All,
Many thanks,
Steve
DISCLAIMER:
sense of it. Business sense. IT sense. Common sense..
Geowebcache-users mailing list
Geowebcache-users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geowebcache-users
Gabriel Roldan
OpenGeo - http://opengeo.org
Hi people!!!, we are progressing on spatialite wfs output format :wink:
WFS output format is working and generating spatialite database file (for now we keep it only on community/spatialite folder, but we have tested it adding files on wfs project folder and running it).
Now we are working on JAR files generation to wrap native libraries (for each OS + arch platform).
So....hopefully during next week we should have it finished with tests included. :slight_smile:
We will keep community updated.
Enjoy weekend !!!
Jose
Thanks, looking forward to see the results
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Hi Jose,
Nice work. I notice from your last commit that a number of the files from the spatialite datastore were copied into the extension. Actually it looks like pretty much the whole datastore. Can you explain why this is done and why the geotools datastore is not being used directly?
If changes are needed to the spatialite datastore a better approach would be to submit patches and patch them directly at the geotools level.
-Justin
On Sat, Jun 25, 2011 at 12:32 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Sat, Jun 25, 2011 at 2:36 AM, Jose Macchi <jmacchi@anonymised.com…2730…> wrote:
So…hopefully during next week we should have it finished with tests
Ing. Andrea Aime
Tech lead
Justin Deoliveira
