Hi Justin,
While fixing GEOS-3993 I went ahead and re-enabled the two GWC integration tests that were commented out in 2.0.x's pom.
They seem to be doing well, I had to fix one of them. Svn blames you as having commented them out so I'm just notifying the change. I don't know exactly why they were commented out but I guess it's due to the random failures?
In any case, just feel free to comment them out again if completely necessary and drop me an email so I can check it out.
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
As far as I remember the tests were consistently failing on the builder server so I commented them out. Glad to see they are working again. If the build server is happy I am happy
On 10-06-21 2:05 AM, Gabriel Roldan wrote:
Hi Justin,
failures?
Gabriel
Justin Deoliveira
Looks like the tests are failing again... at least the testPngIntegration is. How shall we proceed?
Hi Justin,
failures?
Gabriel
Justin Deoliveira
like this:
I take care of it and come back with a solution
cheers,
Gabriel
Hi Justin,
failures?
Gabriel
Gabriel Roldan
Arne, could you please review this changeset: <http://geowebcache.org/trac/changeset/1141>?
Cause of the problem explained at <http://geowebcache.org/trac/ticket/156>\.
Gabriel
like this:
cheers,
Gabriel
Hi Justin,
failures?
Gabriel
Gabriel Roldan
