[Geoserver-devel] GWC master now 1.6-SNAPSHOT, but GS master using GWC 1.5-SNAPSHOT
I notice that GeoWebCache master is now 1.6-SNAPSHOT, but GeoServer master is currently using GWC 1.5-SNAPSHOT. Is this intended, or should GeoServer be tracking GWC master?
GWC stable is 1.3-SNAPSHOT.
Kind regards,
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Hang out on 1.5-SNAPSHOT for a bit, thus far there has been no changes. I expect a bit of variability with a jobmanager pull request, but it should not effect the API.
On Mon, Jul 29, 2013 at 5:18 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Kind regards,
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
See everything from the browser to the database with AppDynamics
Get end-to-end visibility with application monitoring from AppDynamics
Isolate bottlenecks and diagnose root cause in seconds.
Start your free trial of AppDynamics Pro today!
http://pubads.g.doubleclick.net/gampad/clk?id=48808831&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
There are dependency issues:
(1) OpenGeo Hudson geowebcache-master is building 1.6-SNAPHOT
(2) OpenGeo Hudson geowebcache-stable is building 1.3-SNAPHOT
AFAIK no OpenGeo Hudson is building GeoWebCache master; the local repo on Hudson and the deployed builds are probably the last 1.5-SNAPSHOT built from GeoWebCache master. As a consequence, we are probably shipping nightlies with a stale GeoWebCache 1.5-SNAPSHOT. In my view, we should either establish a geowebcache-1.5.x build on OpenGeo Hudson or move GeoServer to GeoWebCache 1.6-SNAPSHOT. Justin?
Kevin, please give us a heads-up if you change the version of GeoWebCache master! Also, do you plan to keep stable on 1.3-SNAPSHOT?
Kind regards,
Ben.
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    Kind regards,
    Software Engineer
    <mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
Ok I think this is fixed now. There was an issue in the geowebcache-1.4.x-nightly job config that was throwing things off.
geowebcache-master → building + deploying 1.6.x
geowebcache-1.5.x → building + deploying 1.5.x
geowebcache-1.4.x → building + deploying 1.4.x
The geowebcache-stable job is disabled will be removed.
On Mon, Jul 29, 2013 at 1:04 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Kind regards,
Ben.
<Ben.Caradoc-Davies@anonymised.com mailto:[Ben.Caradoc-Davies@csiro.au](mailto:Ben.Caradoc-Davies@anonymised.com)> wrote:
Kind regards,
Software Engineer
Geoserver-devel@anonymised.comsourceforge.net
mailto:[Geoserver-devel@anonymised.comsourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Software Engineer
Justin Deoliveira
OpenGeo - http://opengeo.org
