[Geoserver-devel] GWC-page shown instead of redirect to geoserver/web when using Geofence-extension
after updating the GeoServer to 2.22.2 an old error (https://osgeo-org.atlassian.net/browse/GEOS-8331) returned, when using GWC with the Geofence extension.
When I try to open http://localhost:8080/geoserver the site is not redirected to http://localhost:8080/geoserver/web. Instead the GWC-page is shown.
Trying to access http://localhost:8080/geoserver/gwc returns an 404-exception.
Adding “gwc.context.suffix=gwc“ in the “geofence-server.properties” as proposed here https://gis.stackexchange.com/questions/408565/geoserver-homepage-is-showing-geowebcache-homepage, doesn’t fix the issue.
I found a workaround by adding -Dgwc.context.suffix=gwc to the JavaOpts (solution proposed here: https://github.com/geoserver/geofence/issues/235).
Best regards,
Paul
(attachments)
Hi Paul,
adding -Dgwc.context.suffix=gwc to the GeoServer JAVA_OPTS is the way to go.There are some issues about how spring deals with properties, mixing geofence and gwc ones, so the java opt is part of the whole configuration at the moment more than just a workaround.
Emanuele
(attachments)
Emanuele Tajariol
Visit http://bit.ly/gs-services-us for more information.
Ing. Emanuele Tajariol
Technical Lead
GeoSolutions Group
mobile: +39 347 7895230
office: +39 0584 962313
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Emanuele,
thanks for your response. Good to know. Maybe this should be documented in the Geofence-extension docs.
Best regards,
Paul
(attachments)
··· **Paul Biskup** Head of Business Geo Intelligence BGI
Fichtner IT Consulting GmbH
Sarweystraße 3
70191 Stuttgart
Germany
Telefon
+49 (711) 8995 1453
Mobil
+49 (151) 1623 1453
E-mail
Paul.Biskup@…3654…
Sarweystr. 3, 70191 Stuttgart, Germany
Amtsgericht Stuttgart HRB 761846
Board of Directors
Andreas Höfler (Chairman), Dr. Albrecht Reuter
www.fit.fichtner.de
[100_Years.jpg](https://www.fichtner.de)
Erklärungen der Fichtner IT Consulting GmbH, die per E-Mail übermittelt werden, sind nur im Falle schriftlicher Bestätigung rechtsverbindlich.
Bitte achten Sie auf die Umwelt, drucken Sie nur bei Bedarf.
Von: Emanuele Tajariol <emanuele.tajariol@…6887…>
Gesendet: Donnerstag, 23. März 2023 10:34
An: Biskup, Paul <Paul.Biskup@…3654…>
Cc: geoserver-devel@lists.sourceforge.net
Betreff: Re: [Geoserver-devel] GWC-page shown instead of redirect to geoserver/web when using Geofence-extension
ADVICE: This email is from an external source - be careful of attachments and links.
Hi Paul,
Emanuele
On Wed, Mar 22, 2023 at 8:24 PM Biskup, Paul <Paul.Biskup@…3654…> wrote:
Best regards,
Paul
Paul Biskup
BGI
Sarweystraße 3
70191 Stuttgart
Germany
Telefon
+49 (711) 8995 1453
Mobil
+49 (151) 1623 1453
E-mail
Paul.Biskup@…3654…
Board of Directors
www.fit.fichtner.de
Geoserver-devel mailing list
Emanuele Tajariol
Technical Lead
GeoSolutions Group
Hi Paul,
You can easily add documentation - each page has an "Edit" link on the right
sidebar which will take you to a Github online editor.
Brad
