My branch is currently failing the GWC tests due to an NPE when it tries to call getSecurityDispatcher() in WMSService (which is fair because nothing seems to set that). The problem is the code I was working on is all safely off in gs-core-wps and shouldn’t have any affect on GWC integration.
I’ve attached the log in case that might help but while I see a bunch of warnings none of them look odd.
I suspect it might have something to do with the GWC security improvements made by Kevin. I’m currently trying to finish the integration of the GWC rest api upgrade with GeoServer, I’ll keep an I open, and let you know if I come across anything. If by chance I’m able to integrate, I’ll work with Jody to get a PR out because I think this is working in the branch I’m using from Kevin. Unfortunately, Kevin is on holiday this week.
Digging into it there are two test failures in YSLD StyleControlerTest - this is a good test in that it is very brittle of any converters are messed up. I decided to ignore the tests so we would have a working build and we can dig into why those tests are failing tomorrow morning.
I have some early morning meetings and will join you around 9:30 PST, please coordinate on slack and we can get these fixed and the beta release out tomorrow.
