[Geoserver-devel] handling axis order in wms 1.3
I was hoping to get some advice on how to handle the axis ordering issue of wms 1.3. I have a partial approach that seems to work but i have no idea if it is a good one :). And a disclaimer that I have not throughly tested it.
So the first thing I did was update the wms kvp parsing so that the SRS (CRS in wms 1.3) parameter has the explicit EPSG namespace. So basically replacing “EPSG” → “urn:x-ogc:def.crs:EPSG”. Doing that however let to an exception in the WrappingProjectionHandler class that lives in the geotools render module.
Examining that code I found that it calculates the radius of the earth and assumes a longitude/latitude axis ordering. So I played around with a quick hack to basically first check the axis order of the rendering areas envelope crs, and calculate accordingly. And it seemed to work. By flipping the order of coordinates in the BBOX parameter the map rendered properly.
To do the axis order check i basically stole code from GML2EncodingUtils.axisOrder, and shifted it to the CRS class from referencing. And then basically updated WrappingProjectionHandler to use it. See the attached (rough) patch.
So I guess my primary question is whether or not this approach is a good one or not, and if not what a better alternative is.
Thanks!
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
(attachments)
axisorder.patch (4.05 KB)
On Fri, Dec 3, 2010 at 9:36 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
replacing "EPSG" -> "urn:x-ogc:def.crs:EPSG". Doing that however let to an
render module.
The patch works for me, I wanted to bring back the same method in CRS
for different reasons. Just one thing, it's missing a test case.
Eh, there is another way, but you're not going to like it.
The GeoTools referencing system has been built under the assumption that
you want EPSG default axis order and that you'll explicitly ask if you need
otherwise. So if you let it be you have a way to get a CRS in lat/lon order, or
you use CRS.decode(srs, true) and get it in lon/lat instead.
However GeoServer forces the axis to lon/lat on startup and there is no
method to get them otherwise past using urn.
In theory we _could_ stop forcing the lon/lat order on startup and be explicity
in all our decode requests... but I fear that would open a massive can of
works and we'd be flooded :-p
So unless someone wants to go down with that undertaking let's
move on with your patch.
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
On Sat, Dec 4, 2010 at 1:04 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
render module.
for different reasons. Just one thing, it’s missing a test case.
Cool. I will whip up a test case for the final patch and post it in geotools jira.
Eh, there is another way, but you’re not going to like it.
you want EPSG default axis order and that you’ll explicitly ask if you need
In theory we could stop forcing the lon/lat order on startup and be explicity
in all our decode requests… but I fear that would open a massive can of
works and we’d be flooded :-p
So unless someone wants to go down with that undertaking let’s
Agreed. Sounds like quite an undertaking.
Ing. Andrea Aime
fax: +39 0584962313
Justin Deoliveira
